I know we are changing the topic, but Amaroo was awesome. The whole complex was fantastic.
I remember having an intense battle with Gary (sydneykid) in our two 1970 odd model Honda civic on Amaroo dirt circuit back in the late 80's. We were 1st and 2nd outright throughout the whole day against big horse power machines. Each time one of us would go out we would pip the other for first. Gary got me by a tenth of a second in the end on the very last run of the day.
Awesome to have experienced stuff like that :banana:
And if you ever got the chance to race at Catalina in Katoomba (circuit is still there) you would have felt certain parts of your anatomy tightening :) as you drove around it. It was one of those circuits that required full commitment.
Awesome to have experienced stuff like that :D
And if you ever got the chance to race at Catalina in Katoomba (circuit is still there) you would have felt certain parts of your anatomy tightening :( as you drove around it. It was one of those circuits that required full commitment.
Nice memory Boz, I still have that trophy, somewhere in the cabinet, probably needs polishing. :(
I always liked Amaroo dirt circuit, I have a few FTD's from there. I think it was my most successful venue on a wins versus attempts basis. I engineered the car that held the record at Amaroo before Boz knocked it off, so I guess we are about square.
Ahh Catalina, in winter, with the fog in the air and moss growing on the circuit. That was a sphincter tightening experience.
Cheers
Gary
car not ready, targetted scruitiny not done, entry date missed, and no tyres. One or two of those I could sort out but not all 4.
Will be in for Eastern Creek late may instead - but it means I have no chance for the championship this year.
hey its not like I haven't been busy - I'm about to start building my 3rd motor for the year. And I've had the motor in and out 4 times in 4 months!
I need a bloody workshop to do it all. Or even a hoist would be nice.
nah not a chance in production cars - it is class based so if you don't do every round there will be someone from another class that will. Class A have the advantage since there is a bonus point for fastest lap (or pole I can't remember).
But I'll still get out there to cause trouble for the rest of the year :thumbsup:
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
