sorry to steal the thread but is there any PS3 chips out there ? or in the making ?
Would be kool if they got a chip that lets the non-60gigs play ps2 games :w00t: and other stuff.
Nup not yet, hopefully soon though.
Re: the Wii, I have had pretty good success with mine ever since I chipped it. Got my stuff from TechSick, mine is an old one and the chip is only $15. Newer ones are more but there are even solder-less options which is actually pretty handy so you dont have to replace the board like I did.
I must have been lucky so far because all of my games have worked but I have been burning at 4x because I had heard that burning it too fast is no good. Oh and one last thing if you are using a different region game with your chip be very careful because it can sometimes wreck the Wii if it tires to do a software update. Google Wii Brick Blocker to get the software to prevent this.
Cheers
:D Hey Kietz....what school did you go to bud......just need to know so my kids don't go there :w00t:
lyk cum on sled, dere nada problems wiv da speekage of kietz. he be understood laik totally yknow laik effryware him go laik from solsbree down to da norlungar, lyk joo got 2 be d0wn wiv da speek or da bigbubbas be kickin in yr grille when u go 2 da local blue laight disko...kos dey dun kare 4 kops or, laik, dikshunareeez u knowz
ha, ha, good one Ben........you're not a little green alien too by any chance?!
i have a 60 gig. wanna swap plus cash adjustment? haha. need cash for my car.
http://www.ozmodchips.com/
best way to do it is to buy a chipped wii from them cos u get a warranty on it from ozmodchip :P
if u just get it chipped ur warranty is void from nintendo, and u get no other warranty :D
Good offer Damo...if i only had a ps3 to start off with. Not really into games that much any more, havent played my xbox in about 3 years :S. Now waiting for the dust to settle with all the new consoles that cme out and see whats worth buying. At this stage im only considering getting the PS3 because it can play blueray discs, and not that much for the games.
But i heard you can download and play SNES games on Wii ??? if thats true then thats also tempting, chrono trigger ftw!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
