  • Replies 96
I should be good too - providing I get my new rear discs & pads installed & the brakes bled before then!
(Fronts are done).
The 'burbs cruise is better for me - the missus is 6 months pregnant, so squirming around in the hills is a bit of an issue ;)
Edited by BensDR30
(Fronts are done).
The 'burbs cruise is better for me - the missus is 6 months pregnant, so squirming around in the hills is a bit of an issue :thumbsup:
oh good work spose thats gota take priority over the stag, well do a bit of burbs driving and then hills i rekn.. but even threw the hills will b mostly straits... was thinking of threw the bay down nere seaford then threw victa habour rd then back threw the hills via medows n stuff? what do we have to say bout that?? ideasss people ideas!!!
u should do a quick stop at moana car park i live in seaford and am keen as to see a bunch of stags together.
actually it will probly just agrovate me considering i dont have mine yet. lol
oah well what eva u do im sure youl have fun and turn plenty of heads.
reakon i've got another one in on this :)
yeh?? stag? whats the name il add it to the list. :D i spotted a white one in the city lastnight on north tce at like 11ish ?? ne one from here?? let us no if u guys want ne thing/places added to the cruise c how we go.... should i start plotting out a route or r we keen to just swap leaders every so often n c where the night takes us ?? :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
