hey all, well my older brother is very interested in gettin a r33 4 door. Have tried to source info for r33 4 door buying and resellin price for Brisbane however its been tough, since there's not alot of 4 doorz being sold. The car he is interested in (private sale) is:
r33 4 door gts-t BLACK
1995 series 2
Stock as a rock with 60,000km's on it currently
car is black in good condition - both body and interior
he intends to sell the car in a year or so when it has approximately 80,000km's on it
Approximately how much should he pay for it? And Will he have trouble sellin it when he does - 4 doorz sell much much slower do they not. Since there's very low demand for them. HOw much do u reckon he could get for it. He doesnt want it to depreciated too much as he has to head back overseas
thanks
regards
bryanlee38
https://www.sau.com.au/forums/topic/21279-buyin-r33-4-door-turbo-advice-please/
Hey,
does he want auto or manual - auto will automatically be at least $2000 cheaper. remember that to only have 60k on clock it's only travelled 8500km a year. It only indicates one thing they are asking more than even for it since no one only drives a skyline 8500km a year.
He's better off paying $20k to $24k for one (with genuine 80k) and after a year he can wind back the clock himself instead of letting someone else wind it back for him.
4 Doorz
I thought the 4 door models were way cheaper than your standard coupe. I remeber seeing one a little while ago at one of the yards at Underwood, it was a 4 door R33 GTSt Auto totally stock in great condition with about 75000K on the clock and they were asking $14500 for it.
I even took it for a drive and it was straight as, it was obviously used as a family car in Japan
I seriously thought about buying it for a second car, just to absolutely thrash the hell out of it.
4 door skylines is an option if insurance and price is too high.If insurance is not a drama i would be looking at buying a coupe.I dont think he will have problems selling it again but resale price may be an issue.I was lucky and picked my coupe up for 15.It has 18"'s,exhaust and it had been lowered and the paint was pretty good.I looked around for a while but eventually one popped up.As for km's i think it it hard to judge an import on km's.One way to check id to look at the bolt on the crankangle sensor located on the front of the motor(silver disc).It has a silver sticker that goes accross one of the bolts.When the timing belt is done this sticker is torn off so check that out.
Also check out the boot as many r33 leak through the tail lights.
Other things to check for are general rust and paint work imperfections.these are the things i would look for in a car as these are what cost the most and can be frustrating saving for
1)wheels
2)exhaust
3)lowered
Any skyline with these will be a head turner and will be easy to sell again.
theres a r33 4 door up here on the coast for $13k, but its in fairly rough condition, (a bargain I reckon)(auto, 2.5 turbo), I paid around $25k for my impul, which was in perfect nick and had all the goodies etc, but I saw one advertised at autoforce for around 23K, standard, with a body kit,???
so I dont know what is going on and price for 4 door r33 seems to vary alot
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
