I'm sure Ben has pitched a few tents in the back of that thing...
I've carried many types of boxes in the back of that van :starwars:
Was a great day, my van smelt like methanol the whole way to work - perfect way to wakeup at 4am this morning.
  • Replies 114
Of course! Must have had atleast a dozen people pull me up on the stickers by midday today...
love the sig. Ben...well done.
but...on the 8.07 run you took off so quick down the track you forgot to wait for the rope man. If only you could get your vechicle to take off that quick when you are driving on the other side of the wall. :D
Oh I waited, you were too busy wiping up ur mess!
You should have seen Marks reaction at the top end, I yelled out 8.07 out my van window and he jumped into the air. On the way up it was "yessss" on the way down it was "arghh noooo" so close yet so far from a 7.
Then their was some hoon in a datto 1600 pull up trying to pick him up like it was Kings Cross on a friday night!
You're memory is a bit fuzzy, Ben. The Datto was there long before the white van. :D I drove around the bend in the deep beeping and yelling and waving and I could see Mark saying, "Was it? Did I? What was it?"
So close yet so far. Video is uploading now.
how did i know that ben was talking about you?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
