  • Replies 410
Posted Images
Hi all
If i were to fill in and send the L2S Cams form by the end of the week do you think i would have it by then and be able to enter this event? :rant:
Cheers Joey
even if you dont you can get a tempery one from them...Think its on the form down the bottom a slip you can tear off
Or could just get your AASA Joey :) both last a year and recongnised at most places
Guest Joeyz
Or could just get your AASA Joey :rant: both last a year and recongnised at most places
Thanks Jess, I'll fill it in and send it off today. Hopefully it wont take 3 weeks
Should I say that I'm in for the day then?
Yep sure can!!
Tear off the 30day licence part at the bottom of Section 4 , Page 4 on the form :rant:
Cams Form : http://www.cams.com.au/downloads/paperform...Application.pdf
Guest Joeyz
Yep sure can!!
Jess
Do i just keep that just incase i don't receive the licence back from Cams and just bring it on the day?
Steve
Please add me to the list and i'll put the payment through by tuesday next week.
Thanks Joey.
Jess
Steve
Thanks Joey.
I need you to send a copy of Cams form to us also so we know you have applied
Ando, seeing as you no longer have the JapTaxi, are you going to enter your AusTaxi?
Hah ha the VY would bust a nut before the first set of cones.... so no i will quit while ahead... well quit till i get behind another vehicle.. ;) *Chubbs* ;)
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
