  • Replies 410
Posted Images
Hi all
If i were to fill in and send the L2S Cams form by the end of the week do you think i would have it by then and be able to enter this event? :rant:
Cheers Joey
even if you dont you can get a tempery one from them...Think its on the form down the bottom a slip you can tear off
Or could just get your AASA Joey :) both last a year and recongnised at most places
Guest Joeyz
Or could just get your AASA Joey :rant: both last a year and recongnised at most places
Thanks Jess, I'll fill it in and send it off today. Hopefully it wont take 3 weeks
Should I say that I'm in for the day then?
Yep sure can!!
Tear off the 30day licence part at the bottom of Section 4 , Page 4 on the form :rant:
Cams Form : http://www.cams.com.au/downloads/paperform...Application.pdf
Guest Joeyz
Yep sure can!!
Jess
Do i just keep that just incase i don't receive the licence back from Cams and just bring it on the day?
Steve
Please add me to the list and i'll put the payment through by tuesday next week.
Thanks Joey.
Jess
Steve
Thanks Joey.
I need you to send a copy of Cams form to us also so we know you have applied
Ando, seeing as you no longer have the JapTaxi, are you going to enter your AusTaxi?
Hah ha the VY would bust a nut before the first set of cones.... so no i will quit while ahead... well quit till i get behind another vehicle.. ;) *Chubbs* ;)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
