Guest INASNT
Originally posted by R31Nismoid
You forget what you posted?
:) ok!
i just hope r34gtt didnt buy the kit from that james guy in st albans who trades under the name option house performance coz the turbo looks legit but he does hes own welding and sells em off as hks, apexi and other jap brand stuff!!
  • Replies 64
yeah i bought in st albans but wasnt off OH performance.the bloke i got it off bought it off him 3 months ago.apparently brand new for 9k. yeah that prick is dodgy as, been there before and ran away.when you see the manifold you will know its a nice one definaltely machine welded me reckons.has slots machined out to prevent cracking and shit.im stoked with what i got. all in perfect nick and very high quality.
ps: when i went to OH he had cast hks end tanks and was welding em onto el cheap o cores.
pss : 3037s are ball bearing or bush bearing???
psss: turbo is high mount turbo will be a tad higher that rocker cover
Guest INASNT
yes that option house guy is a dodgy ****! I just asked coz i other i know seen an similiar add for 3037 kit and he contact number was his. I gotta check out this manifold when i get back to mel
when this turbo comes on boost will depend on which exhaust housing he is running. given that the engine is an RB25DET and that they flow quite well as they are, the turbo shouldn't be too laggy.
nice package dude, good luck, it should serve you quite well.
