hey guys i got a few sets of 6000kg jack stands(brand new). there really good for the zed because of the hight it can raise them to and there cup were the car sits is perfect size for the zed chassis, sits perfectly. i changed my clutch with the aid of these, specs:
Max Working Load: 3500 Kg each or 7000 kg as a pair
Min Height: 408mm (16")
Max Height: 616mm (24 - 1/4")
Base Dimensions: 298mm x 260mm
Ratchet Mechanism for quick adjustments
Weight: Approx 7 Kg per Stand
Meets AUSTRALIAN STANDARDS
these sell for $160 A PAIR at supercheap, ill sell 2 pairs for $160 smile.gif
https://www.sau.com.au/forums/topic/213144-jack-stands/
hey guys, pick up is in the brighton area. yes i can seperate not a problem i have a couple of sets. postage is $40 anywere in australia (for 2 pairs of stands). heres a pic of them:
Edited by aut0
https://www.sau.com.au/forums/topic/213144-jack-stands/#findComment-3765827
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
