Item: Mach 1 BOV (Loudest BOV in GFB product range)
Age: ONLY 1 month on the car
Condition: EXCELLENT!
Price: $250
To Fit: (What car) Any Car, however adaptor is needed for diff car types (i have one 4 GTT R34)
Contact: PM Only
Comments:
With the BOV(Cost me $300), ILL INCLUDE FOR FREE:
- 2 Different type of trumpets which you can screw on and off for different cool dump sounds (It cost me $35 for each trumpet)
- GTT R34 Adaptor with all the pipes and all (Adaptor cost me $70)
IT WILL HONESTLY TAKE 2 MINS TO FIT ON GTT R34 as everything is there
BTW pics will be added if required, however it'll be on my engine. It will be taken off as soon as someone is willing to buy it.
Prefer pick up!
Edited by R33Turbo
https://www.sau.com.au/forums/topic/213370-gfb-mach-1-bov/
  • 1 month later...
BUMP!!! Man its real nice and loud BOV, nice show off valve if ya know wat i mean.
I just wanna get the HKS SSQV one.
IT cost me $400 in total to get it on my car, and im giving it away for $250 when its so close to brand new.
ILL post up pics ASAP!
Edited by R33Turbo
https://www.sau.com.au/forums/topic/213370-gfb-mach-1-bov/#findComment-3867726
it can be converted into a plumb back bov with little work~
I had this BOV plumbed back for a while cuz the cops told me to take it off or plumb it back. And i did it within 5 mins.
But at the moment i made it so it dumps atmo.
Ill post up pics in a minute
Edited by R33Turbo
https://www.sau.com.au/forums/topic/213370-gfb-mach-1-bov/#findComment-3868624
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
