Hi B-man, we used a GCG 450 bhp ball bearing hi flowed RB25DET turbo on a RB30DET (RB25DE head). It made 290 rwkw on the RB30DET at 6,250 rpm compared with 220 rwkw on the RB25DET at 7,000 rpm. Amazingly both were at 1.3 bar.
There are a few issues with this comparison;
The RB30DET had a ported cylinder head, the RB25DET was standard
The RB30DET had adjustable camshaft pulleys, the RB25DET didn't
The RB30DET had a split dump pipe, the RB25DET didn't
The RB30DET had a 3.5" exhaust and no cat, the RB25DET was 3" with a cat of unknown quality
The RB30DET had standard RB25DE camshafts, the RB25DET had standard RB25DET camshafts
My summation, the RB30DET breathed a lot easier (porting, inlet, cams exhaust) and therefore the turbo was able to spin a few more RPM and produce more airflow at the same boost.
We are just about to do the same thing on an RB31DET (RB30E block and crank + RB26 top end) with a GCG 500 BHP ball bearing hi flowed RB25DET turbo. I want to break through 300 rwkw with a hi flowed turbo and a standard GTR intercooler. Then we will stick the GT3040BB on it as the target is a responsive 600 bhp.
Bottom line, I'd give it a go B-man.
Thanks sydneykid, Its good to see a direct comparrison with what you've done to what we do over here.
The motor on the above plot has no headwork at all, standard cams and pulleys, was through a standard R32 GTR intercooler, 3 inch exhaust and was at 1.4 bar (NOS brings it up a bit.) without NOS we got 270rwkw at 1.3 bar and I remember you said somehwere that the roller dyno uses about 20kw more than a hub dyno so we must be close!!! That same engine in a totally complete GTS4 with me in it (all up 1800+kg) on stuffed 18in road tyres with no drag wheel alignment, just straight off the street runs 1.7 60ft and mid 11's @ 200kph. Thats all with a totally stock internal motor.........Regards Rob.
Hi B-man, No VVT that's why I chose an RB25DE top end over a RB25DET. At the time I thought all RB25DE's didn't have VVT and only RB25DET's did. But since then I have updated my knowledge and found there are RB25DE's with VVT. We were using the standard R32 ECU (chipped) and it didn't have VVT drivers, so that's the main reason I went for the RB25DE top end. The other is the more aggressive camshaft timing and lift.
I have never tried RB25DE camshafts in an RB25DET head. The only problem I can see is if it's an RB25DE without VVT it will not have the drive pegs on the inlet camshaft. If they are from an RB25DE with VVT then it will and they should fit straight in. I don't know if the RB25DE VVT camshafts are as aggressive in timing as the non VVT ones. I suspect not, as the VVT is mainly used to comply with tighter polution regulations which may also require less aggressive camshaft timing and lift.
Hope that helps
PS for RIPS; we use a Dyno Dynamics roller dyno and all numbers I quote are "real" on the day, not ambient compensated using Shootout mode.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
