in may of last year i was ludicrously charged for a burnout that never happened, (even if i did happen, they wouldnt have been able to see it) and the monkeys tried to defect me too, but were too dumb to do so. a more detailed description can be found in this thread...
http://www.skylinesaustralia.com/forums/Lu...icrous+policing
in november, i was raped in the most unfair hearing since lindy chamberlain. the cops flat out lied, changed their stories, creatively interpreted photographic evidence, et al. magistrate swallowed it all, and more or less assumed i was a baby-killing hoon, based on the babble the prosecution made about "the flagship of nissan performance". $570 fine, 3 month suspension.
today, i finally got my appeal before a judge in district court. and he found the allegations so absurd, and my evidence/arguments so damning, he threw it out in less than an hour. the crown prosecutor in his wisdom, didnt offer one word in argument. the monkey cops were blatantly exposed as fabricating a charge against me, and willingly giving false evidence in court.
will anything come of it? i doubt it. cant even claim my expenses, which total several hundred dollars even though i represented myself lol.
just wanted to share my elation at beating the system, and my annoyance that it probably cost tens of thousands of taxpayers dollars to reach this solution.
note: some of you may be aware i was booked for speeding a couple of days ago in highly dubious circumstances, and am now very confident i will get off that too.
regards,
mitch
https://www.sau.com.au/forums/topic/213432-me-1-police-0/
I won a court case against the police it took me all day at court I represented myself too. I had about 3 prosecutors 1 was getting led by the other two. The two flamin mongrelstable lied so much I ripped into them regarding their story and the lack of evidence the magistrate could see how the police was trying to take advantage of me. After I won i also made a official complaint to the Qld Police Service that’s always good for record too. The senior detergent from the cop shop was not happy at all.
I wish there was a www.dobinacop.com.au site it would get soo many hits.
There are 3 sorts of people that you can't trust IMO.
Car Sales Man a Lawyer and a Cop these days.
https://www.sau.com.au/forums/topic/213432-me-1-police-0/#findComment-3771234
Just wondering; do you have any legal experience at all - degree or anything?
Or did u read up yourself and give it a go?
haha none at all. i must confess i have always had a talent for debates/arguments though. the judge even commented that he thought i was wasted in my job and i should definitely study law lol.
at the original hearing, i definitely went in far too cocky, and my inexperience was fatal. but i learnt an awful lot. i also had to attend district court to get a date for my appeal, since it was to be adjourned, watched a few cases, and took notes as to how they were run. it was of major assistance, and i would recommend this highly.
this time, i dominated proceedings. and used all the lingo "if i may your honour..." etc. it was a lot of fun, but somewhat stressful. didnt get to shout OBJECTION unfortunately...
im very confident i will get off my recent speeding charge now. (yes im the green citroen guy lol, see thread http://www.skylinesaustralia.com/forums/Se...ective+policing)
i already have tons of questions to smash the po-po in cross-examination. and i know how to object to them bringing in circumstantial evidence, which they nearly always do.
in a few months time there might be a ME 2. Police 0. thread. or one about the court system being a joke lol depending on the result.
cheers!
https://www.sau.com.au/forums/topic/213432-me-1-police-0/#findComment-3771801
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
