18's definitely. 19's in that style would look too big in my opinion.
18's would be lighter, therefore car will be slightly faster. 18's would have cheaper tyres, therefore more money in the bank for other modifications.
https://www.sau.com.au/forums/topic/213537-18-or-19-rims/#findComment-3772116
The clearing of the calipers will depend on the spoke design. You can't rely on the offset to clear it.
Check out the wheel offset thread Sydneykid made. It's pinned so you can't miss it.
There should be a thread recently made in the suspension section or cosmetic section about what you want as well.
https://www.sau.com.au/forums/topic/213537-18-or-19-rims/#findComment-3774081
You haven't said what you want to use the car for at any point. If you only want to use it on the street, and want it to look good, you can go 19's, but I reckon its too big anyway. If you are planning to do any form of motorsport, 18's would be a lot better. Remember, every mod should suit your application.
https://www.sau.com.au/forums/topic/213537-18-or-19-rims/#findComment-3779613
the use would be daily drive, i think im going 18's, nicer drive, and suits the car more than most 19's (IMO) . also my dad rekons r33's were made when 19's didnt even exist or used much and it dosnt suit the car (thats just one persons oppionion dont take it to heart) when you see like an old hk monaro in 20's it dosnt look right, coz that car was brought out with like 13's
https://www.sau.com.au/forums/topic/213537-18-or-19-rims/#findComment-3782904
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
