  • Replies 207
good man !!!
hey i forgot to say that i like your ride man.... i dont really like R33's but there are a few an yours is one
good work!
thanks mate. ur one of the first people to comment me on my car. i dont get many . i really appreciate it. Cheers
Hmm i dont know if pat will be attending. But his wheels will be :rofl:
HAHAHAHHAHAHAHAHAHHAHAHAHAHAHAHAHHAHAHAHAHAHAHHAHAHAHAHYHAHAHAHAHAHAHAHAHAHAHAHA
thats funny as.... cause its the truth
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
