  • Replies 52
yes s3 gtr xenon headlights fit BUT IT is no easy job and they dont just bolt on.
i bought a set and put them on my car, it took me along time to get them to fit correctly, as you need to trim alot of the headlight and ballast mount. and because you trim the mounts also there is nothing holding the headlight in place unless you make mounts and secure them.
Also the plugs are different so you can cut up the gtr ones or chop them off and put the gts-t on them.
stock s1 gts-t grill also doesn't fit correctly.
its far from an easy job and when you have to trim/cut up headlights which are worth more than $2000 each from nissan it does hurt
dont ask me whose car this is. i dont know. he's on here tho. tuffest front on a r33 i've seen tho
post-30915-1207725884_thumb.jpgpost-30915-1207725816_thumb.jpgpost-30915-1207725770_thumb.jpg
Im in love :( Thats the same frount bar and side mirrors as myn lol now iv just gotta find them and see what i can do and if i can keep it legal
Would this mean gtr lights on a gts-t are iilegal? i was thinking if i did the angel lights using my sr1 base and frount lense i could maybe engineer them.
Not sure if that sounds stupid but i really like thoses lights
those headlights are illegal because the globes are no case in anything. if you do a retro fit to your s1 headlights then it will be fine.
there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)
"there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)"
$300 ?? does that mean you send them your lights and they modify them? I think they look wicked.
"dont ask me whose car this is. i dont know. he's on here tho.
Reduced 91%"
If i did this to my car but made a fiberglass moulding for it, would it pass or would i need a clear lense in front too??
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
