  • 3 weeks later...
Stopped by Fibrevision today and spoke to Bruce.
We were waiting on an R34 coupe to come in but it's been over a month and it's a no show so far. We were going to see what EXACTLY needed to be done. But i've seen Bruce's work, 100% confident we can do it now.
But either way it will be done after I get back from Japan. Hoping January 2009. But I'm in no rush to be honest. :whistling:
But either way it will be done after I get back from Japan. Hoping January 2009. But I'm in no rush to be honest. :laugh:
Good luck! hope to see a good result! i been looking into aswell.
  • 5 weeks later...
Well I COMPLETELY forgot (so did Bruce at FB) about the lower reverse lights on the R34 Coupe. As I saw my friend reverse his 2 door 34 onto my lawn I was like aww f**k!
I'm scrapping this idea, but I definitly encourage any high rollers with the coin to make it happen, I think it'd look mint.
Cost-wise you would need about $3,000 for the main brake lights area etc, and then I'd estimate a further 800-$1,000 for the lower reverse lights section.
In terms of what needs to be done, that Skylude post gives is a good example. http://www.cardomain.com/ride/553310
reshaping the bootlid to fit it in is the main thing that needs to be done. Decided not to go ahead as I'm aiming for a 34R late 2009, early '10. :)
I'm scrapping this idea, but I definitely encourage any high rollers with the coin to make it happen, I think it'd look mint.
reshaping the bootlid to fit it in is the main thing that needs to be done. Decided not to go ahead as I'm aiming for a 34R late 2009, early '10. :thumbsup:
looking at this: http://www.skylinesaustralia.com/forums/in...t&id=126480
and looking at the rear bar. would it be possible just to fit a coupe rear bar to your 4door for the lower reverse lights? they look very similar but theres probably slight differences that you cant tell from that pic
probably not as straightforward as that but still.
Edited by G0DZLR
Correct that would be the way to do it but a whole lot of modifying to fit and re-wiring, as the 2 door rear kit goes more around the sides then the sedan, and it's not a striaght swap. And of course the $$. So I'm bailing on the idea. Was good while it lasted. lol.
Edited by Magic
When I get the money I'll pick up the baton..
Good to know that fibrevision are up to the job though, I've sourced some GTR front fenders, some I'm doing my front end atm...
Will do the arse later down the track..
  • 8 years later...
  • 2 years later...
  • 2 years later...
  • 1 month later...
  • 1 year later...
I've been looking into the swap owning a sedan for a while and have managed to get a deal on a coupe  so I will do what I can and keep anyone who is still viewing this and wanting to see progression of it.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
