hey guys since ivew had the car the 'clearcoat' on my wheel's alloy part has been funny, i wanna get the clear stripped off and the alloy polished nice n shiny again, every polisher/wheel restoral place ive been to says its too hard to get into the spots with their machines, anyone know how i can hand polish the shit off/bring it up ? or know anyone who can do it for me, everywhere wants me to take ym two piece welded wheels that are worth a fair bit of money apart to do it which im NOT prepared to do... thanks guys
https://www.sau.com.au/forums/topic/21465-need-my-damn-wheels-polished/
For something like that they should be able to sandblast it?? Maybe that is a bit extreme, might damage the alloy.
Anyway, there are methods by which they high pressure hose it with "whatever", that should get in all the gaps and strip it right back. Don't know much about it, but know it can be done.
dude u cant sandblast alloy it will destroy it im a metal polisher it is pretty hard to pollish them without the right machine but can b done r they the rims in your pic? if u want the clear off get paint stripper but make sure u dont leave it to long or it will eat the alloy
yeh it is bloking it u will be there all day with that stuff just use a bit of paint stripper make sure u dont get it on what u dont want polished its nasty stuff and dont leave it on long as it will eat the alloy afta a while, i have neva polished them with autosol but if u can get a buff with some normal car polish and give them a buff if that dont work give us a yell if u not to far away i might b able to do it for u as long as u have more rims as i dont know how long it will take.
how can i clear them when they are on the car ? or how do i get them fully polished ? or ami pretty much ****ed ? coz if its gunna be too hard i guess its time for new mags for me and ill sell these, only thing is i love these m,ags so much they suit the car big time :D
if u can get a set of standard rims do so and take your rims of the tyres its the only way u will polish them properly then u juct clear them like u would a car. i dont know of anyone who can do it as u need a special machine, i can polish just about anything by hand as long as they dont have heaps of spokes it not to hard but your first thing u need to do is get the rims of the tyres. where bouts in melb r u?
so this is what i gotta do (just checking)
-remove wheels from car (is taking the tyre off essential, like will polish or paint stripper damage them ?)
-strip off clea coat with paint stripper (being careful not to leave on too long or get on parts that i dont want stripped (and clean off with water)
-polish and buff with a metal cleaner/polisher like autosol ? (or can u recommend something better)
-if this does work and they come up good how often do i clean them and do i just use something like mag acid cleaner or something ? or do i need to polish/buff often ? if i dont polish/buff often can the metal get eaten away or rust ?
yeh do all that and yeh to get it done properly take the tyres off, u will need a proper buff to get in everywhere and yeh just use polish that will cut and polish it well, if u dont want to be polishing them all the time get them cleared afta u happy with the polish job. post me to c how u goin with them ok.
yer mate but how are they cleared ? if places wont polish them then wopuldnt clearing them be just as hard ? if i gotta remove the tyres then what ill have to do is take 2 off (borrow g/fs car) jot down to tyrepower get tyres removed.. do the work get them cleared back to tyrepower to re-fit tyres.. then repeat for two more tyres... *sigh* lol
hmm just had some paint thinners lieing around, would that work like stripper or is stripper better ?
the thinners did nothing but clean the dirt off the rims... so io got some ruffish sand paper and tried a small part, it got rid of the 'marks' easily as, polished it with autosol and it seems to look good considering it was ruff sandpaper... if i got some real smooth paper could i just sandpaper the whole rims and autosol polish them up ? or would it come up looking shitty ?
i think sanding is the only way unless paint stripper and fix it up as i put thinners on and didnt seem to do anything, but then cleaned that off and polished with autosol/buffed with a rag but it didnt dso anything to the marks ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
