  • Replies 108
I think there is a difference. Normally, an external wastegate is mounted on a separate pipe from the exhaust manifold. So when the wastegate is opened, some air bypasses flowing through the turbo. If the wastegate is mounted on the exhaust housing of the turbo, the exhaust air always flows into the turbo and then out through the wastegate...so the air never bypasses the turbo.
Guest 570CK
Hope you get good hp.
I got the bill for my car today. Half of the bill was fixing up the fark ups the other shop did.
The dodgy shop grinded a piece out of my turbo!!!!!!!!!!! I didn't spend $2300 on a 800hp turbo so some fark nut could grind it.
Anyway. 2 page list of screw ups.
So good luck rob :)
Sheesh! That is a big turbo!! Almost like that white JUN s15 in Perth with the T88 on it. Which makes me wonder, why didn't you go all the way with a T88? I would have with that sized turbo :) I think lag monster is an understatement :) Anyway, should be fun. Do you use it on the street, or as a strict drag car?
When does the car come on boost? I am guessing it starts to make boost around 4500rpm? 5000rpm?
Guest 570CK
about 4500 u get a large surge.
Depends which t88 he has. My turbo is the same size as the smallest t88. Tho the bigger t88 are 1000hp rating.
I just wanted to go for the Garrett. The T88 never crossed my mind.
It a street car, never set foot on the 1/4 mile. Just want it to be a dyno car with gas.
Guest 570CK
Originally posted by rbs13
that sounds awesome.. i was braggin about getting all crossed up at the end of 2nd.. into 3rd.. pff.. 4ths my new goal..  hey 57ock i seen you getting round brissy a bit.. nice car.. where abouts you go crusing on weekends if at all?
Might go to coast this weekend. Haven't been for 3 months.
Street car? Wow! I am guessing you usually drive off boost, unless you thrash the car around? :) Not sure what T88 it is, but it's been in many mags. I'm sure you've seen/read it. I think it has a 2.2L stroker kit too.
Can I ask why Garrett? Not HKS? I guess Garrett is a lot cheaper than HKS and TRUST. Never thought about a smaller turbo? I mean, I thought a GT30 would be good enough on a SR20. Unless you are chasing insane power like 600hp+? Is that what you're chasing??? How much boost are you running and what's your power output?
Guest 570CK
Yeah I've seen that Jun s15. Goes very well.
I'll stop soon as I get 500rwhp
At the moment its only running 14psi as it still has stock internals.
Which are getting replaced hopefully at the end of the year. Was running 17-18psi when I took it too dyno shop.
I'll get a kw figure tomorrow for my pissy 14psi :) over 230 for 14psi over 270 for 17 going by one of the work man there
Well its all done. Cars damn noisey now with the external gate, might have to look into some sort of resonator to keep the noise down even with a external wastegate line that plumbs back into the exhaust. I'll attach the dyno sheets, there are 2, one shows the boost and how quickly (or slowly I should say) it comes on the other shows my afr. The power curve is quite ugly midrange where the stock ecu dumps a whole heap of fuel into the map and then by the top end its sitting about right where its making huge amounts of power. The car is much quicker, as you can imagine, but the lag is quite bad. Firstly I need to reset my sbc as all the functions have been dropped cos the battery was disconnected for so long. Now I definately need a bigger fuel pump, bigger injectors and then I can think about a new ecu to fix up my ugly power curve. Its pretty promising so far, I just wish it wasnt so laggy, but that can be partially fixed by setting up the gain correctly on my sbc and then with a new ecu and advancing the ignition maps a bit. I think we can safely say I will reach 400hp by the end of it at the treads quite easily.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
