You'll be able to get your hands on a set through one of the traders on here. If not them, just keep an eye on other members' for sale threads. And if not them, yahooauctions Japan.
You're looking at $2.2k upwards for a second hand set with decent width and offset. $3k+ or something if you're looking at brand new.
Edited by adam-__-
could be wrong, but think this is it here:
http://www.terra2imports.ca/import-japan116361654092911.htm
if so, the kit is Final Konnexion.
Cheers mate.. Much appreciated
But what is the long red thing under the steering collum?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
