Not sure on costs but Mobile Injector Service can do highflowing. I reccomend spending the money and buying bigger injectors tho.
What are some reasons to upgrade to bigger injectors apart from just having a newer item in there?
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio.I woulnd tget hi flow ones my old man has had bad expericence with them.I just buy new ones and so be it plus there nto that expensive now, you can get 555cc nismo ones for aound 750 to 850 a set
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio...
Yeah i knew that bit :P
...I woulnd tget hi flow ones my old man has had bad expericence with them...
What kind of bad experience? what happened?
stock rb25det injectors can be highflowed to approx 650cc with out losing their spray pattern once u go bigger than that ur pattern starts going all over the shop. Mobile Injector Services do these and i think they're roughly $400 and the injectors are pretty much brand new.
Yeah i knew that bit :laugh:
Well basically the guy who did these ones,( dont want to name anyone except he is from towommba area) didnt do a very good job of them plus its a bit ruthless to do them.The spray pattern is crap,like a turning on a garden house and one of the pintels in the number 4 injector was broken from his bad doing and caused number 4 piston to basically crack the length of it in two.All the fuel was washing oil off the bore,hence causing damage.Spray pattern is important.IM not sure on Rb25 injectors but these were on SR20det ones.
Highflowed R34 ones from the US....good option www.deatschwerks.com
they are awesome i had a set of them, they were flow tested a 600cc they were all with in 2cc of each other and gave me mo problems what so ever
I just had a look on the site and they look very professional. Are they new OEM injectors that they high flow, pressure test, etc, etc and resell? Is that how it works?
when i got my injectors cleaned i talked to the injector guy about highflows and he said he wouldn't ever touch them, he said he's seen some good ones but on the most part they we all crap different flow rates etc. Your motor your risk.
thats why when you get them you flow test them :laugh: like i said mine were all within 2cc, if you test them you cant go wrong
Hey hey,
I'm just looking for some names and numbers of people that highflow std R34 rb25 injectors in Brissie. What are some costs and options???
thanks guys,
Steve
why hi-flow std injectors.
you can buy some aftermarket injector for a bit more money than hi-flow std injectors.
much better way to do and brand new too
cheers
thats why when you get them you flow test them :D like i said mine were all within 2cc, if you test them you cant go wrong
Yep, they even have so many cores in stock, they flow test and match a group of 6 so the tolerance between them is very close. I've heard nothing but praise for Deatschwerks, my ones have been running great for a long time now.
They highflow the pintle exactly the same way a manufacturer would, using micron accurate drills an CNC.
yeah i nearly got a set of deathworks highflows as well but read more than a couple of bad reports of injectors failing, locking up on the dyno and sorts. But I suppose bad reports are everywhere for everything
Edited by SevenAngryPenguins
cheers
because they are cheaper and made by the same process and are effectively new
dont tell any one else that though...cause when you mention anything besides nismo when it comes to injectors they are apparently shit
I just heard they have arrived at my house... why do work days always go for so long?
I grabbed the 600cc variation of them. they are so cheap for brand new, flow tested & matched, 600cc injectors that are a drop in straight fitment... That has to be as good or better than any aftermarket brand injector, right???
And they only cost $550!
:D
Don't forget to send your ones back for cash-back!......another $90in your pocket
do they take stock ones off of any one? Or only current customers? i have like 3 sets of RB 25 ones and 2 sets of SR20 ones!
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
