Not sure on costs but Mobile Injector Service can do highflowing. I reccomend spending the money and buying bigger injectors tho.
What are some reasons to upgrade to bigger injectors apart from just having a newer item in there?
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio.I woulnd tget hi flow ones my old man has had bad expericence with them.I just buy new ones and so be it plus there nto that expensive now, you can get 555cc nismo ones for aound 750 to 850 a set
when your stock injectors cant flow enough fuel to your engine from either turbo increase or just boost pressure you need more fuel to equal the amount of air going in on a ratio...
Yeah i knew that bit :P
...I woulnd tget hi flow ones my old man has had bad expericence with them...
What kind of bad experience? what happened?
stock rb25det injectors can be highflowed to approx 650cc with out losing their spray pattern once u go bigger than that ur pattern starts going all over the shop. Mobile Injector Services do these and i think they're roughly $400 and the injectors are pretty much brand new.
Yeah i knew that bit :laugh:
Well basically the guy who did these ones,( dont want to name anyone except he is from towommba area) didnt do a very good job of them plus its a bit ruthless to do them.The spray pattern is crap,like a turning on a garden house and one of the pintels in the number 4 injector was broken from his bad doing and caused number 4 piston to basically crack the length of it in two.All the fuel was washing oil off the bore,hence causing damage.Spray pattern is important.IM not sure on Rb25 injectors but these were on SR20det ones.
Highflowed R34 ones from the US....good option www.deatschwerks.com
they are awesome i had a set of them, they were flow tested a 600cc they were all with in 2cc of each other and gave me mo problems what so ever
I just had a look on the site and they look very professional. Are they new OEM injectors that they high flow, pressure test, etc, etc and resell? Is that how it works?
when i got my injectors cleaned i talked to the injector guy about highflows and he said he wouldn't ever touch them, he said he's seen some good ones but on the most part they we all crap different flow rates etc. Your motor your risk.
thats why when you get them you flow test them :laugh: like i said mine were all within 2cc, if you test them you cant go wrong
Hey hey,
I'm just looking for some names and numbers of people that highflow std R34 rb25 injectors in Brissie. What are some costs and options???
thanks guys,
Steve
why hi-flow std injectors.
you can buy some aftermarket injector for a bit more money than hi-flow std injectors.
much better way to do and brand new too
cheers
thats why when you get them you flow test them :D like i said mine were all within 2cc, if you test them you cant go wrong
Yep, they even have so many cores in stock, they flow test and match a group of 6 so the tolerance between them is very close. I've heard nothing but praise for Deatschwerks, my ones have been running great for a long time now.
They highflow the pintle exactly the same way a manufacturer would, using micron accurate drills an CNC.
yeah i nearly got a set of deathworks highflows as well but read more than a couple of bad reports of injectors failing, locking up on the dyno and sorts. But I suppose bad reports are everywhere for everything
Edited by SevenAngryPenguins
cheers
because they are cheaper and made by the same process and are effectively new
dont tell any one else that though...cause when you mention anything besides nismo when it comes to injectors they are apparently shit
I just heard they have arrived at my house... why do work days always go for so long?
I grabbed the 600cc variation of them. they are so cheap for brand new, flow tested & matched, 600cc injectors that are a drop in straight fitment... That has to be as good or better than any aftermarket brand injector, right???
And they only cost $550!
:D
Don't forget to send your ones back for cash-back!......another $90in your pocket
do they take stock ones off of any one? Or only current customers? i have like 3 sets of RB 25 ones and 2 sets of SR20 ones!
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
