Ive been thinking and heard alot of good things about puting a r33 RB25DE or T on my RB30ET block and selling my intake and exhaust manifolds 4 rb25 items.
Ive been doing alot of searching and reading about it on here and on the skyline forums.
Is it possible to have the RB25 head shaven to bring compression up to 8.5:1 on my standard rb30et block ?? (I no i could use the NA block but dont really wanna pull motor out as its fairly fresh).
Cheers
https://www.sau.com.au/forums/topic/215102-rb3025-question/
RB30E I heard is the better option. The block I used was a N/A block that had done around 400,000klms :P , machined up and did the job perfectly. I'm not sure of compression ratio though, but wasn't too high or low took lots of boost without detonating or troubles we guess-timated around 8.5:1. Plus they are initially cheap to buy.
Edited by nismomiles33
https://www.sau.com.au/forums/topic/215102-rb3025-question/#findComment-3820808
why raise the compression.....just stick a big turbo on it and go for 10 second qautermiles,
young fella here n nz has done exactley that. twin cam turbo head on his auto vl commie, changed the loom n ecu, fitted and front mount, stucks sum 265's on the rear, wound the boost up to 14 psi and ran a 10.4 on his first run.
my first conversion was a rb30/R33 25de striaght swap, the only new thing i bought was a head gasket and head bolts ...the only work done to it was to face it and weld up the oil gallery to the hydralic lifters. stuck it straight on, bolted on a idleler pulley for the cam belt and reassembled it.
i then drilled and tapped a qauter inch fitting into the intake side of the head back into the gallery that had been welded up, fitted a brass t piece behind the oil pressure sensor and connected the two with a hose. ran 13.2 exactly as described above, no extra go fast bits or engine work done.
the way to do it would be use your et block a na twin cam head and then turbo it.
Edited by nizmonut
https://www.sau.com.au/forums/topic/215102-rb3025-question/#findComment-3821543
Because the car will drive like a piece of shit with compression that low (30ET + 25/26 head)
Mate I think your best option is to sell your current package and buy a RB30E, or rebuild with correct compression pistons.
https://www.sau.com.au/forums/topic/215102-rb3025-question/#findComment-3821640
Thanks everyone for all the responces,
I have kinda Been going through the 300+ page thread for info.
Thanks for the pdf doc f*kin unreal..... exactly what i was after :down: (Legend the person that wrote it)
Ive just got and bought a rb30e block from the wreaks for 100 bucks :P lol started to strip it down last night but mates came around.....
Im gunna use standard rods but give them a polish maybe send them away for shotpeening??
I also donno wether to do Forged pistions or us NA standard pistons (over size if the bore needs machining)
Ive heared alot of people dont bother about using the piston oil squirters from the rb25 block? R they really that nessecery?
Sounds tricky and im gunna be doing the full build myself in my old mans smash repair shed.
Also will be using standard rb25de head with heavy duty valve springs.
I would like between 300rwkw maybe a little more but i want fast spool for the street. was thinking of using a hypergear TR44
they seem like a decent budget turbo made and balanced in Melbourne Australia.
Edited by mr30_2.4e
https://www.sau.com.au/forums/topic/215102-rb3025-question/#findComment-3822761
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
