Right hand drive?
Because they cost of converting them isn't worth it? Because even the americans think they're lacklustre cars.
The same reason nobody imports any american car (<30 years).
Fair point, so you cant import one direct from Mitsubishi? with the wheel on the right side of the car :D
Edited by -FIGJAM-
The way I see it,
the Eclipse GSX: AWD model equipped with a 210 hp (160 kW) turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine was the only decent one.
The later models, I guess for what it is, was OK but not a fan of FWD.
Also, Iam not to sure how much it is to import one in but if the cost all add up with doing the Left hand to Right hand drive covnersion, I would happily go for an EVO IX or EVO X.
  • 4 weeks later...
well considering left hand drive has become legal since what i have heard in the past few years....
im not sure.my dad owned a 59 corvette a few years back and he told me that there are alot of left hand drive cars out htere.
i looooooooooove the green eclipse from F&F. AWD turbo. very nice car. the one in 2F2F is gay. front wheel drive v6 ....just shit(alright on the vw vr6 but not a long ugly car)
and i dont know why they would make the 2nd main car in 2f2f another eclpise but newer model. it could have been something different...plenty of cars i could think of.....
There are many better all wheel drive turbo cars and they are in Aus and RHD....
But then again if you did get one it would be unique. I have never seen one on the road here, they arent for me but I can understand why someone might want one. But if you did get one would you do it up like the one on F&F? With the OTT spoilers, kit and vinlys?? :P
you can be safe in the knowledge that any crap they pump out this time around couldnt possibly be worse than 2F2F
Apparently its connecting to the first one again. It'll have Vin Diesel in it again. so yea, we'll see how its gonna turn out....
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
