  • Replies 40
Bam I think you will find that paintball is *illegal* in W.A ( The only state I believe it is illegal in by the way ) but it is a lesser evil so to speak.... whilst it is illegal it is generally accepted in the community... I have heard multiple stories in the past about police actually going on these days as its good practice for themselves in the field....
Without the right sort of protective gear, generally the face masks (ski masks things that have goggles for your eyes and protect your mouth/neck) its quite a dangerous sport. You can lose an eye to a paintball (they really do travel extremely fast) so I can understand why it'd be illegal but done right its damn good fun. btw: I havent seen 1 establishment that doesnt supply all the safety gear, just stating it could be dangerous if not done right.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
