Make: 1997 Nissan Skyline R33 GTS-T with Type M Kit
Model: Series 2
Transmission: Manual
Colour: Silver
KM: 143***
RWC supplied: Yes
Currently registered: April 09
Contact: 0421 821 863
Due to an unexpected event I am moving over seas mid June this year, unfortunately this means that it is time to sell the skyline.
I bought this car last approximately 1 year ago in immaculate condition, it was thoroughly tested before it was purchased at Dr Drift’s work shop where it compression tested a balanced 155 PSI in ever cylinder. Apart from the intercooler I have installed, this car has had no engine modifications since day one. It has never been boosted, never been drifted or tracked. The car is serviced in 5,000km intervals, last service gearbox oil, diff oil brake fluid and a full radiator flush was completed.
Engine:
- K&N Pod Filter
- Hybrid front mount Intercooler & Pipe Kit
- 3” Cat back exhaust - Legal
Suspension:
- Damper Adjustable Koni Yellows all round with custom Springs
- Front Nismo Strut Brace
- Rear Strut brace
- Spare set of Bilstein Shocks front and rear (in need of a rebuild)
Exterior:
- Series 2 type M body kit with lower front Lip (Looks very tough in the flesh)
- 17 inch 5 spoke dished rims
- Hankook K107 Tires 235/45/17 front, 245/45/17 Rear (Tires Have done 8,000km)
Interior
- HKS Boost gauge and Water temp Gage (Comes in HKS double din gauge holder)
- Trust Gear knob
- Pioneer head unit
- Pioneer Competition Splits (Front)
- Pioneer 6x9’s (Rear)
- Pioneer 10 inch Sub
- Pioneer V12 amp
* Interior has been kept very clean, minor wear on the drivers right hand side bucket.
Alarm: Has an alarm / Immob. Key less entry
Extra’s:
Parts I have purchased in the last month with intention to modify the car.
- Walbro fuel pump
- Apexi duel chamber Blow Off Valve
- Turbo Smart Boost controller
Price:
$15,000 - For entire package
$14,000 – With out Sound System
$13,500 - With out Sound System and Spare Bilstein Suspension
Edited by dondee
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
