Parts required to complete R34 GTR bonnet conversion,
1 R34 GTR bonnet.
2 A pair of R34 GTR bonnet hinges.
3 An R34 GTR bonnet latch.
4 An R34 GTR bonnet stay.
5 An aftermarket mole to join the GTR bonnet to the standard R34 front bar.
Thx mate.. pretty crazy... suppose you bought the bits and pieces from nissan ?
PHAT!.. Id like to drive a car with reclinable bucket seats like yours and compair them to my fixed back.. see how big/small the diffrence is..
Nice seats Eug very similar to my ones I had in my 33.. I miss bucket seats so much.. I'm too big for the dam s13 seats lol
i've ridden in a side of bride ergo 1.5 which is more fitting for different body types from tall/fat/skinny it still holds you in.
a fixed back is awesome - such good holding capabilities, can be uncomfortable for daily driving though - the car is already uncomfortable as it is.
the R34 GTR seats are a very good compromise, they are suited more for the smaller driver though. I'm 170cm and around 70kg and i'm quite snug in them.
if only you lived in brissy
cheers... yeah they are awesome. pity they are worth a turbo conversion/half a build of a new motor. worth it though - if you actually use them for what they are meant to be for.
hey eug
nice center console :w00t:
hahaha nicely spotted... bah who needs it!
those holes in the seat are begging to be filled with a harness!
YOU KNOW YOU WANT TO! :thumbsup:
probably not for a while, looks like the car is coming off the road soon. target is 170~200 rwkw NA
you guys might hate me for it, as it won't be RB
If only you knew the grief you are about to wreak upon yourself eug. :thumbsup:
*Mr Burns's voicerolling finger tips on eachother*
Excelent
excellent indeed... doing the research on it now. put it simply there's no way i could achieve this kind of performance from an RB with the same amount of money. has the potential for 500HP and upwards!!!!
any takers???
P.S. - check out these V-Spec II seats that just came up for sale. got wood?
price i would budget AT LEAST $2.5K (maybe closer to $3K to your door) the auction ends in 30 mins
http://page2.auctions.yahoo.co.jp/jp/auction/b85665688
shouldn't you be selling your car, not modding it!! :P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
