Thanks guys, these pics has to be the best photos I've taken.
Maybe if any of you guys need some photos of your cars, we can go on a photoshoot :) I'm in SE Melb by the way.
And as for lowering....EVERYONE tells me to lower it, but I don't want to spend too much money on this NA.
How much will the cheapest lowering be? WITHOUT cutting my springs...
Hey Guys,
Here is my little beauty, picked her up 2 weeks ago from the importers
Compliancer even left the xenons in for me.
Came with a stock tape deck which I had to quickly replace
Btw - FS rare genuin nissan dolby tape deck - $300 :)
Will take pics of mine soon and post them up White R34 with matt black 18" rims, will get my Bomex bodykit installed within the next 8 weeks, (have to wait for the rear bar to come from overseas, that delays me 5 weeks :D)
I will post my current set up ( practically stock) and when i redo my car all those weeks later if this thread is still alive i will post my future set up, with hood, front, rear, sides, lowered slightly, tinted windows etc etc all done.
just keep this thread alive!
its an awesome thread and it really shows the N/A scene here. Although personally a stock GTR looks far hotter than all our n/a's put together haha....damn those super sexy gtr's! :)
YES! I love the mount of 4 doors comming through!
But that makes mine less unique :down:
As for cheapest lowering.. all you need is a set of lower springs (shockies are advised too, unless you want your car to handle like oil tanker) try Lovelle or KYB or King springs.. all fairly cheap springs and shokie set ups
Maybe if any of you guys need some photos of your cars, we can go on a photoshoot :D I'm in SE Melb by the way.
I just bought a set of lowered springs, but not the best way to go about it. But it cost me $450 which included labour...
Prob best to get a set of adjustable struts... But then you could look anywhere from around $1000...
So in your case maybe springs to fit the budget.
Had my liner for a couple of month now. V happy with it :)
Charles89 is a very good friend of mine and kindly took some killer pics for me.
His now looking for clients interested in him taking photos for them.. PM me if interested.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
