Where'd you get the CF Lip from? How much are they?
Origin Japan make them. around $350. They are real carbon fibre, have to remove the boots brake light tho and then stick it on. If you want one let me know :)
Man.. I love that!
Its farkin fat! You NEED Genador style mirrors man!!!
Thanks Mate
Mirrors would be good, but i would rather get side skirts and rear pods first.
Actually as of 2 hours ago a passenger front guard would also be good, It got hit by something/someone while i was in the shops and left a nice scratch/dent
Edited by ShanO`
BLLLLLLIIIIIIIIINNNNNNGGGGGGGGG BLLLLLLLIIIIINNNNNNNNNGGGGGGGG!
I love it!.. the inner arch wheel photo is sick!..
How much more diffrent are braided brake lines than stockos? Pedal feel? Temp resistance?
It feels like u get alot more pedal feel. Still havent got out to the track yet to see how they pull up but in the hills they feel awesome.
Got the carbon surround from Superior in Japan roughly $190 which just sticks on top of the original. Leaving the gauges like that :) if i was gonna do something it would be gtr mfd but not just yet lol.
Hey guy's
Im only on my L's n just brought this N/A r33
Here's a pik... hope use like it!
p.s any modification ideas/opinion's be awesom
thanks
hey man
thats a hot skyline u got
do you know what type of body kit u got?
so what mods have u done to it?
pm me
thanks
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
