Do you by any chance go to University of western sydney, im pretty sure i saw this skyline. what caught my eye was the GTT or nismo style body kit and the nice set of rims, i thought it was a turbo until i saw the Green p plates.
Yeah I do. I've seen you around a few times trying to find parking lol.. Your one a non turbo too? Use to have the same rims as you when I first got my car
It's a small world...yea it is a non turbo still on my red P's till october. As for the car its stock havent had the chance to do anything to it. Anyway awesome ride, i have only ever seen your's and another black Skyline without the spoiler and the back lowered considerably. UWS skylines need to represent show up some of the Supra's and Silvia's i have seen around hahaha.
Here's my RB25DE Manual R33. Swapped it for my old GTS-T R32 which had stuffed rings. I love it although the Rb25DE's are disguistingly slow. Also you may notice i took the spoiler off, that's becuase i like the fins it leaves behind. It's becoming a trend with these R33's over in NZ. Looks more aggressive.
Definately not the best looking NA here but tidy enough!
On the topic of fast N/A's, i have owned a RB30E skyline, RB20DE and RB25DE skyline and i can say that my girlfriends SR20DE can beat any of them. Maybe they are the way to go for a faster NA?
She has an S14 Silvia with a turbo sized exhaust and CAI. Mind you, Rb25DE neo is the only NA skyline i havn't driven, my R33 is just the VVT model. At the very least, her SR20DE is miles ahead of the RB20DE.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
