Make: 96' Nissan Skyline GTS25T
Milage: 85,000km
Transmission: 5 speed
Colour: Grey Silver
Complied? Yes
RWC supplied? Yes
Currently registered? Till Feb 09
Price: $16,000neg
Contact: Via Pm or 0410 687 984
Comments / Modifications:
This has all been done by Matt @ BEL...........
**Tube & Fin Front Mount Intercooler
**Garrett 3076 only done 2000km
**Ems 8860 ( this is one best Aftermarket computer going around Now)
**Os Giken Twin Plate clutch
**Greddy profec B sepc II
**Tial Wastegate 38mm
**Nismo 740cc injectors
**Walbro Fuel Pump
**Sard Fuel Reg
**D1 spec Catch can
**K&N pod with custom box
**Liverpool exhaust Custom 3" mendrel bend exhaust.
**Spitfire Coils
This car is a dream to drive. Standard internals Running still at 157comp on all.
9psi = 220rwkw
14psi = 250rwkw
17psi = 271rwkw
https://www.sau.com.au/forums/topic/215787-96-nissan-skyline-gts25t-271rwkw/
  • Replies 40
Well hopefully some will be intrested in 16
Had no luck...................
I am in no rush man ...... if it goes then it goes
  • 4 weeks later...
16k!!
Give it some time and the right person will come along!! Just gotta be patient.
But then again 33 market is flooded and the prices are dropping like crazy :)
Edited by siddr20
I agree with siddr20, even if you wanted 13 thousand you'd still be somewhat hard pressed, but when people see a modified 12 year old car then it's going to be hard, is the car on carsales.com?
nah what i meant was.. keep it at 16k.. dont bring it down further!!
its such a tasetful car with some really nice mods :teehee: someone will appriceate it and buy it!!
gdluck
do you pay more for the plates each year? what gauges are mounted on the b-pillar? did the ems plug in? does it need any type of engineer cert for anything / could you be defected for anything? bov?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
