Hi guys, i am thinking of getting defis for my er34 soon but as my car has the lcd screen option (am selling the screen to someone in the forum already) thus i have a pretty level surface if i want to have the defis sitting on the centre console but now the thing is, im not sure if that is legal and if it would get me a yellow "post-it" :down: another choice i have would be to have the defis on the A pillar whichever option is legal? im looking at having 3 gauges by the way. pics of three gauges (not factory ones) sitting in a 34 would be great.
https://www.sau.com.au/forums/topic/215819-getting-gauges/
lol~ well, im trying to "minimize" the chance or else my gf will force me to sell the car!! has FMIC, 3", dump pipe and BOV now already... going to the pits = sell car or 3 years of naggings... :down: both looks nice to me but havent see much of 3 gauge pod holder though... cos next i will be getting a boost controller so i guess that may be sitting in front of the speedo or somewhere else....
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3812618
lol GF's opinion on YOUR car = nothing
my girlfriend hates my brother's TME EVO because it looks like a 'done up' Lancer *shakes head*
doesn't like this because of THAT, doesn't like that because of THIS
lol don't worry, you'll hardly get picked on for having gauges, just tell her cops don't mind...
try and say whatever you have to say to make her believe or think the car is perfect and won't get picked on
lol then you can keep the car AND the girlfriend, win win :D
my2c
Andrew :down:
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3812687
but the factory facia is not able to fit the defis in i heard... what about smaller sizes ike 52mm instead of 60mm? This is the reason why i am trying to get the factory facia cos i wanna put the defis in it but was told by some that it will not fit... ;)
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3815808
Three gauges on the piller will be a bit much I reckon. I have the GReddy pillar mount on my R33 with two gauges, and it looks good, but three would be way to cluttered. Don't think it would fit too well. Go for the the top of the dash where the GTT's normally have it. I like that look on my R34. Just hoping to change for white faced dials at some point. For the three on the dash as well as the guage cluster ;)
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3815912
why not get a GTR cover and make a custom panel to hold them in, should fit 4 if done right or 3 and the turbo time etc.
Something like this
http://page14.auctions.yahoo.co.jp/jp/auction/s92762375
Then get a fiber glass panel made to put the guages on.
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3816105
i like the look of the R34 GTT style guages on the dash looks good like that i think greenline sells a guage holder that goes on the dash :D they also have one that goes around the speedo thingy ill post a pic !
I like the looks too and it will certainly look very legal. would you be able to get me a pic of the holder greenline is selling? i really wanna do something to my car before my pay finishes. :blink: or i might get a DVD player 1st. Was thinking of maybe just a turbo gauge by the right side (mearcat) and forget about the rest. but was worried that i might need the rest next time... hahaha... im so full of contradictions aye... my bad... yea, chi100188, would appreciate if you can get me contacts and pics so i can think about it. Cheers mate! looking forward to a cruise and my day off to clash so i can come along and see everyone's dash!! hahaha
https://www.sau.com.au/forums/topic/215819-getting-gauges/#findComment-3817349
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
