Hi all just wanted some opinions....
Tonight i installed a HKS SSQV in my rx7 and the piece of shit doesn't work. I welded on the flange to the pipe, put the o-ring in the flange, put the bov over it and put in the cir clip. T-Pieced the vacuum line off the FPR. Thought sweet no worries... Took it for a drive and low and behold massive turbo flutter just like before. Thought no worries ive stuffed something, probably vacuum, pulled off the vacuum line to the bov and could feel/hear the suction. I thought It was probably stuck shut form living on my shelf for three months. Pulled it all off, put a screw driver in and pushed the second stage all the way open, then put another screw driver in and pushed the 1st stage open as well. Thought to myself yep i think it was stuck because i herd that cracking noise when a seal hasn't opened in a while.
Put it all back together took it for another drive on 6psi, no bov sound all flutter, changed to 14psi same again.
Got the shits, picked up my ball and bat and went home
that and the sun went down
So my questions are:
how do i bench test the ssqv?
does it need to see vacuum like a normal bov or does it magically just need positive pressure for the reference?
how the bloody hell does it work? i cant work out how it could ever overcome the pipe pressure to open?
Thanks Acea
Edited by 84ace
https://www.sau.com.au/forums/topic/215822-hks-ssqv-broken-fixed/
biggest mistake i see a lot of people do because they are too lazy to find a real vacuum line.
Do people know that this is dangerous, and since your adding crap to this mission critical line, it might leak \ come apart and lean the engine, and possibly kill it at high revs?
I've even seen someone dumb enough to run a line from the front of the engine off the FPR line, over the top of the engine down onto the turbo boost controller... Hot engine, rubber hose.. attached to a FPR line.
If I were you, I'd plump that line to a better spot to start with anyway.
with my set up i have two choices, i can t-piece the FPR and boost gauge line, which i did or i can t-piece the microtech map sensor line. I think i chose the right one, considering how critical the microtech is to the "mission," anyway... its pretty easy to see when the boost gauge continuously reads 0 instead of reading plus or minus half a brick. I think i would pick up a problem with that line pretty quickly.
So that leaves me with another option, drill and tap a new fitting into the manifold. No.
so back to it... either there inst enough volume of air getting to the bov or its broked....
you have more choices
what ever happened to the original BOV line? did it magically disappear?
There is one for the factory boost guage
THere is another back there just sitting around doing nothing
there are more free if you choose to remove your carbon canister.
Map sensor, and FPR pressure, are definately mission critical lines, so stay away from them. You do realise a f**kup on that line and a sudden drop of fuel pressure could blow your engine? Also, the BOV could cause fluctuations on the FPR pressure, making it go all over the place? I can't confirm that, but its definately a possibility..
Couldnt agree more. In 5 years of working with dynos ive seen 3 cars blow motors over vacuum hoses blowing off. Both had dodgy BOV plumbing, two on the FPR, the other on the MAP sensor. When you are at full throttle on the dyno, it takes about 0.1 seconds for the motor to blow.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
