FINALLY got my professors from japan...
chucked 'em on the car this week along with greddy coilovers, front and rear castor and camber kit, 33 GTR seats and a host of other suspension bits and bobs... next week is caliper detailing...
they're 18 x 8.5 +30 (225/40/18 dunlop le mans) & 18 x 9.5 +30 (245/40/18 dunlop le mans)
VERY hapy with the look!
HUUUUGE THANX to J - Imports for coming through with the goods... again :down:
https://www.sau.com.au/forums/topic/215833-new-rims-are-here-finally/
  • Replies 47
meisters and SSR1s only look good with alot of offsett.
unfortunately in this case its not happening.
not sure if its the wheels or the colour of the car.........but something dosnt look right
my 2c
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
