the aerial is working fine, goes up and down when switched on and off.
The adaptor I got was a straight plug in from the jap 2 pronged wire to a single prong wire. It was actually listed for nissan's. I will look up the product when I get home tonighy
Adam
IN european car the rear dimsiter is the aerial, as i dont have a skyline atm i not sure if this theroy applies.
could be that when the dimsiter is on it casues some sort of electrmantic filed of heat. Witch then casue the frequency of the radio station to become distored and weak becasuse their is a field it needs to get through. Try buying a amplifer the the antenta. will boost up volume and respection.
cheers
Mayb ther'e is noise super imposed on the demister voltage. Maybe put a 0.1 Uf cap on there to chasis ground. This will make it look like a short to any aleranting current or noise on the demister. DC wont go through the cap, cus it's like a hi-pass filter.
Just a thought . Never Had the problem. My arial is in front windscreen.
Madtrang,
Where did you get the window aerial from? i got one from stathfield radios and was wondering how good they actually work! removing the stock arial from my R33 so wondering how good radio quality is from these window arials!!
this is mainly because they say to hook up to the demisters if signal is low!!! perhaps this issue will affect me too afters this install!!!
any info would be good!
Cheers
The r32 gtst of mine atcualy has the areial in side the front window. Stock. I think it also could be tuned for picking up frequnecy in the 70 - 90 mhz Band. Not 2 sure, but I think all hte higher stations dont receive as goood as the lower ones.
I rekon u be better sticking to the normal arieal, rather than a window one,
I'd like to know how a normal window one is attached. I think mine is actually inside the glass. Going 2 b bad if i ever get my front window smashed. But I never listen 2 radio anyway.
well the one i got has an arial unit that sits under the parcel tray, but can be attached to the positive wire of rear demister for better reception!!!
main reason im getting rid of the arial is because it's always up even when only lstening to CD's and looks crap! also with the GT wing can open the boot when the radio is on --- which is always !
see how it goes anyway, thanks for the info!
Hmm, mayb u should try hooking up a switch for areal up and down. Or a witch brings areal down on boot pop. Would not b 2 hard. But the looking crap part can't help u there. Could b worse could have a coat hangar instead. :-)
Yeah finished watching third stage movie. Just other night. Downloaded the hole lot of the net. About six Gb worth. Cant wait till they make another stage. Whatched every stage now. So addictive.
Been wanting to buy the whole set, but dont realy want to put on a credit card and get it from over seas.. yet..
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
