the aerial is working fine, goes up and down when switched on and off.
The adaptor I got was a straight plug in from the jap 2 pronged wire to a single prong wire. It was actually listed for nissan's. I will look up the product when I get home tonighy
Adam
IN european car the rear dimsiter is the aerial, as i dont have a skyline atm i not sure if this theroy applies.
could be that when the dimsiter is on it casues some sort of electrmantic filed of heat. Witch then casue the frequency of the radio station to become distored and weak becasuse their is a field it needs to get through. Try buying a amplifer the the antenta. will boost up volume and respection.
cheers
Mayb ther'e is noise super imposed on the demister voltage. Maybe put a 0.1 Uf cap on there to chasis ground. This will make it look like a short to any aleranting current or noise on the demister. DC wont go through the cap, cus it's like a hi-pass filter.
Just a thought . Never Had the problem. My arial is in front windscreen.
Madtrang,
Where did you get the window aerial from? i got one from stathfield radios and was wondering how good they actually work! removing the stock arial from my R33 so wondering how good radio quality is from these window arials!!
this is mainly because they say to hook up to the demisters if signal is low!!! perhaps this issue will affect me too afters this install!!!
any info would be good!
Cheers
The r32 gtst of mine atcualy has the areial in side the front window. Stock. I think it also could be tuned for picking up frequnecy in the 70 - 90 mhz Band. Not 2 sure, but I think all hte higher stations dont receive as goood as the lower ones.
I rekon u be better sticking to the normal arieal, rather than a window one,
I'd like to know how a normal window one is attached. I think mine is actually inside the glass. Going 2 b bad if i ever get my front window smashed. But I never listen 2 radio anyway.
well the one i got has an arial unit that sits under the parcel tray, but can be attached to the positive wire of rear demister for better reception!!!
main reason im getting rid of the arial is because it's always up even when only lstening to CD's and looks crap! also with the GT wing can open the boot when the radio is on --- which is always !
see how it goes anyway, thanks for the info!
Hmm, mayb u should try hooking up a switch for areal up and down. Or a witch brings areal down on boot pop. Would not b 2 hard. But the looking crap part can't help u there. Could b worse could have a coat hangar instead. :-)
Yeah finished watching third stage movie. Just other night. Downloaded the hole lot of the net. About six Gb worth. Cant wait till they make another stage. Whatched every stage now. So addictive.
Been wanting to buy the whole set, but dont realy want to put on a credit card and get it from over seas.. yet..
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
