eng cert does not come from workshops, you have to go to the pit and get a list of approved engineers. The ones I had, he is a retired mechanical engineer.
he looked at the Australian standards for the vehicle and compare it with what you have. he'll then make a report to be submitted to the pits.
They have nothing to do with garages as they are meant to me impartial third party
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3816310
pit, vehicle inspection centre I think its named that way because of the hole underneath to inspect the underside of the car. They do it this way in W.A not sure in melb. I don't recomend getting eng cert unless you got yellow sticker.. its quite expensive
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3816448
Im using the guys in Braeside - Enkelman and Associates
They are quite good, a few people i know have used them now and their prices are some of the best in Vic.
Some engineers are charging far too much but these guys are good priced
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3817782
Really im just about to go get my R32 GTST complainced can they beat 1200??? i got most of the work such as oil change, brakes , everything that makes car RW, its fully stock except exhaust it has a cat thow, and pod filter but its properly put on and jdoes not jiggle around or anything , plus my car was bought in under 15 yo rule one of the last to be brought in under that,
Edited by BRUNSKIGTST
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3818896
I also used Enkelman and Associates for my Pulsar, I needed an engineers to legally drive around with an SR20DET in the car. It was expensive, but they were extremely reasonable about the modifications.
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3819140
Compliance and Engineers are two totally different things.
You need an engineers as but a part of compliance
$1200 is normal for compliance non DIY (things like AC gas, seat belt are other things that need doing etc)
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3819206
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
