Hey Mate,
Pretty sure you just need to fit a Oil Filter Sandwich Plate and a sender. The plate goes where the Oil Filter is and then that allows you to put in the sender. Then thats where you get a reading from.
They are at the bottom of this link. :P
http://justjap.com/store/home.php?cat=267
(If im wrong, please correct me) Cheers!
go to kb auto one....supercheap might have one. its called a oil sensor adapter. basically a brass extension with 1 hole to stick in the unit.
u then take out stock oil pressure unit. wack in this adapter. then wack in the stock pressure sensor and wack in your sensor.
feed off the oil at the oil pressure sensor location.
found its best......had a fair few leaking sandwich plates!!
sort of similar to this=
hppp_0608_oil_16_s%20accusump_preoiler_cm_remote_filter_install%20electronic_pressure_control_and_pressure_switch_fitting.jpg
Edited by r33cruiser
thanks for the solutions guys but sound liek answeres to mechanical guages mine are electrical
Or you can do as above or do what i did go done to enzed and get a tee and have both gauges cost me about 5 bucks
nah mate. theys are for electronic gauges as well. the sender has a thread on it right.
just screw it into the adapter i have posted....or as the bloke above me said get a double adapter. then once its in do your thing. hook up the earth and signal wire.
done
  • 1 year later...
im looking do do the same thing can anyone tell me whe size the threds are ?? or are the aftermarket sensors different?
  • 3 years later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
