Gokarting Now Booked For Fri 8 Aug 8pm Gepps Cross $50 Pay Bunny By 31 July
  • Replies 398
Posted Images
I am digging this one up as i really want this to happen now that the LAN is out of the way.
Lets try and get this happening!! :down:
haven't forgot about this yet
should have my roster sorted out by the end of the week to start planning something more concrete
PM me the time, date and place please and i will be there
i hate driving after gokarting.....you end up thinking ur still in the go kart and yes....
Edited by Krishy
going to oranize the dates this week, then i'll have to sort out the deposit
My experience from organising these things mate.....organise a small meet spot or something and get like $10 deposit off people to confirm that they are coming....that way numbers wont drop like flies on that day....just a suggestion mate...good luck
first one i organised, i took 10 bux from everyone, and still a couple didnt show, next one i didnt, i just paid the deposit myself and everyone plus more showed up. Karting isnt really the kind of event people dont show upto.
I too am willing to pay a deposit so just give me to details and "BAM" payment will be made!
By the way MADAZ, I'll have to grab Initial D off you soon now that I have my car back :D
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
