NOT INTERESTED IN SWAPS
Make: Nissan
Model: 1993 R32 Skyline
Milage: 156600
Transmission: 5 speed manual
Colour: White
RWC supplied? YES
Currently registered? YES 5 MONTHS REGO REMAINING
Price: $12500 ono
Contact: Josh 0408151300
Comments / Modifications:
1993 White r32 gtst skyline, GTR bonnet ,
trial gtr front bar( not painted just in white undercoat),
GTR grill, Trust side skirts and rear pods, eyelids not fitted but included.
Four wheel steering disabled. T04E turbo upgraded
(360 degree thrust bearing, front wheel and all internals replaced),
Top mounted stainless manifold, HKS Style external wastegate with 14psi spring,
3inch end tanks (silicone joiners), custom intercooler piping,
19 row oil cooler with remote oil filter and braided lines,
Blitz BOV (plumbed back into intake), 440cc GTR injectors,
550hp walbro intank fuel pump, Nismo fuel pressure regulator,
Nismo cam gears with gates reinforced timing belt,
new tensioners and pulleys (changed at 110000kms).
Genuine Nissan head gasket, MS air filter, LINK ECU,
Map sensor and incar display (laptop software, USB port). Oil catch can,
Excedy heavy duty clutch, DBA slotted front discs,
DBA standard rear discs, Bendix ultimate front pads and rear pads,
GAB front shocks with aftermarket springs, Ohlins rear coilovers/ Eibach springs,
Aftermarket camber arms, Aftermarket castor rods,
Rays engineering white 3 spoke wheels. Front tyres 225/45r17,
rear 235/45r17. Aftermarket steering wheel, Sony CD player,
Alpine 6x9 rear 3 way speakers with clarion front speakers.
5% tint on rear and quarter glass, 25% tint front windows.
Apexi turbo timer, central locking with remote and alarm.
Boost gauge, front and rear sway bar. Made 175kw on safe tune heaps more potential.
EL dial dash lights, Sunroof. 156600kms. Rego until august 2008.
Phone Josh 0408151300 located in ipswich qld
Only selling because i want a ute for work. Has a current safety certificate
(personalised number plates have been replaced plates are now 977KWS)
Images:
Edited by R32 White
https://www.sau.com.au/forums/topic/216256-93-model-r32-skyline-12500-qld-ono/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
