Just managed to place my turbo timer to where it suited earth, parking sensor and speen wires are connected. Now I know the blue green & red wires are to be tapped into the ignition wires only problem is I dont know what the skyline wire code is that go to the ignition, on and accessory
please reply back if you got the answer
cheers
https://www.sau.com.au/forums/topic/216335-greddy-turbo-timer/
You might be better posting in the General Maintenance forum?
You can get a wiring harness for most turbo timers, so they are "plug and play" - that way you dont need to cut that many wires, and if you get defected and need to remove it, its easy to unplug it.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
