Hey all- My current flatmate is moving out this coming Sunday/Monday, and I will have a room available in my 2 bedroom apartment at Annandale.
The room is fairly small, but you're welcome to stack any excess furniture you may have in the space in the loungeroom.
Rent is $140 per week, paid fortnightly, and must be kept 2 weeks in advance at all times. Cost to move in is up to $280 for rent in advance + $500 bond.
No smoking/burning of any substance allowed inside and no pets :D
It's a great location- 2nd level apartment with city glimpses, only 6 minutes to the city by car, and a 3 minute walk along Johnston St to Parramatta road buses. Light rail station is at the Blackwattle Bay end of the street, too.
Send me a PM if you are interested and I'll provide you with my mobile number.
Cheers,
Shaun.
https://www.sau.com.au/forums/topic/216357-room-to-let/
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
