Item: genuine r32 gtr n1 headlights
Age: not sure
Condition: very good condition, just some surface scratches as usual but or else in very good condition
Price: $580
To Fit: (What car) r32 gtr, or if you want im pretty sure they will fit r32 gtst
Contact: Tony 0412862091
Comments:
up for sale is pair of genuine nissan skyline r32 gtr n1 headlights, these are very hard to come across these days so who will be the lucky buyer,
cheers
Edited by GTRBOS
https://www.sau.com.au/forums/topic/216606-r32-gtr-genuine-n1-headlights/
those are headlights that came out on r32 gtst's from 93-94. Genuine N1 headlights have the clips moulded onto the headlights which allow you to clip on the grille and also N1's use a H1 bulb
Guest
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
