Since pod filters are illegal unless enclosed, how would a good panel filter (such as K&N) compare with a pod? I can't see the panel filter allowing anywhere near as much airflow.
Also, should I just go ahead and put a pod filter in my '89 celica? It's not like I'm gonna get pulled over and inspected right?
https://www.sau.com.au/forums/topic/21672-pod-vs-panel-filter/
Good panel filters, K&N, redline and the likes are very close to as good as a pod.
i persoanlly prefer a pod cause of the noise which some think is too ricey.
dont really know squat about celicas turbo or not buy if its not turbo it wont make a noise and wont attract the cops as much, i had a pod on my old NA car and it didnt make a noise so you should be sweet
yer cold air #1....
u can get proper boxed made for the pods unique autosports have them but obviously they would cost a bit but id say it would be better than a pannel, i got a cover round mine mainly just a temprary one i used out of heat proof aluminium jus to pass my defect, only cost me 15 bucks to do untill i get the money for a carbon air box
cheers....
www.freewebs.com/2BNVS_r33
honestly, how can you seriously measure a device like this on a dyno. Is a dyno fan providing anything like normal airflow. How many of you drive around with the bonnet up?
personally, I have to go for the pod because the stock box won't work with a fmic... otherwise, it would be a panel all the way - hopefully with an aftermarket induction setup (or a ghetto DIY setup at worst).
Originally posted by Jimbo2000
so are the UAS ones legal?
i am thinking of getting one.
another workshop near there make a SERIOUS one for like 500
I'm pretty sure they're legal, I've never seen an air box which has some sort of ADR approval stamp or sticker on it like brake lines for example.
The other workshop wouldn't be Hills Motorsports would it? ;) Their box is made from aluminium and seals better than the UAS one. At the cost you mentioned though it's really only worthwhile if you have lots of money to burn. I got the cheaper fibreglass one from UAS for around $160 I think. It does the job well enough.
This whole air-filter business is really quite amusing.
Normal atmospheric pressure is around 410 inches of water gauge pressure, so if your stock air filter has say 4 inches of water pressure drop at full power, you are seeing (406/410) or 99% atmospheric pressure after the air-filter.
So you fit some monstrous expensive aftermarket air filter box or pod, that is advertised as having guaranteed TWICE the airflow of the stock filter. So you fit it, and sure enough there is now only two inches of water pressure drop at full power. There is now 408/410) or 99.5% atmospheric pressure. So expect an 0.5% power gain.
A far more important consideration is air temperature. Air density works from absolute temperature (the Kelvin scale). To convert Celsius to Kelvin you add 273. So 27C equals 300K.
So for every three degrees of temperature rise, you loose one percent in air density, which equates to roughly one percent power.
So your new super air filter has about the same effect on power as lowering the intake air temperature about 1.5 degrees.
So use whatever type of air-filter you want, or is convenient, and concentrate on getting the coldest possible inlet air. There are far greater gains to be had that way.
But a lot of guys prefer a brightly coloured chrome pod right behind the radiator, because it looks nice when you open the bonnet.
On the other hand a stock air-box with partially concealed cold air pickup behind the front bumper, will probably work far better and keep the cops happy as well.
I ran mine on the dyno when it was making 164rwkw with a pod and with the stock air box & stock new filter.
They both made exactly the same power.
Both were run with the bonnet open.
Since then I've modded my standard airbox. It now has a 100mm CAI using PVC piping with a 45degree bend that enters the air box where the standard small arsed cai was. I've grabbed my self some plastic and a bit of superglue & silicon to old it all to get her and make it look flush. Pop the bonnet and it looks stock. Everything is black and unless you really know something about skylines you wouldn't pick it.
It has made the bov and induction/turbo whistle heaps louder.
It should now be ok for the 450-500hp that I am chasing :P
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
