however proceeded to pick on the space saver tyre in the boot having little tread and windscreen wipers a bit worn on one end of them (one inch long). Not sure what I can do from here...
Clutching at straws :yes:
Considering some of the POS on the road that are around, I think they were just jealous of your ride.
Best of luck mate.
  • Replies 43
With regards to going over the pits and which pit branch..IT DOES NOT really matter...
I mean I got yellowed once and ended up getting more defects once I was there (no grill in front of the intercooler, small tear on the drivers seat, steering cololum lever "to hard" to adjust, coilvers)
Ahh coilovers... thats a funny one.
The first inspector failed the coilovers.. (said ride was too hard)
The second inspector passed them with flying colurs.. (quote "it not hard at all" unquote......)
Lesson learned that day.................. wether you pass or fail certain modes depends on the individual inspector!!!!!!!!!!!!!!!!!!
I’ve generally had good inspectors, I tend to chat to them a bit as they are doing their thing, last one was importing a s14 race rally for track/drift work and had some good advice about what really is or isn't legal for road use. It’s not the inspection that bothers me, it’s the whole bending over and taking it because that’s how it is...
Now who knows where I can find the actual legislation regarding the yellow sticker?
i got a yellow on sat night for blown headlight globes. cop didnt even pop the bonnet so he missed the high mount. BUT he put the yellow on a 90 deg angle to the side of the windscreen for some reason he told me it was cos i wasnt allowed to drive it at night. wasnt even being a flamin mongrel or anything. chances are great that i wil now have a very expensive track car.
Ouch that sucks :) Just peel the sticker off & put it back on straight. If it's on at an angle or far inside the windscreen its sort of like a code to the pits to go ahead & ream you....
When you take it over have the boost as low as you can go & hope you get a reasonable inspector that won't make you get permits, that leads to bulk fun...
dpi.gov.au tells you jack site... I even called them asking for the information or where I could find it and they said they could not help me....
What sort of legislation are you trying to find out? What its for, why they have them, etc etc..
:D ossie 21 spent like 3 years tryin to get his yellow off. in the end he had to take the head inspector out for dinner and blow all the other techs on site. i suggest you do the same. he had to... even though he enjoyed it.. you may to.
cheers :P:banana::banana::banana::banana::banana::banana::banana:
Edited by simor32
found out today one of the inspectors in town is an old mate. so it should come easily. have an appointment tomoro he said the sideways stickers means jack it was just the cop being a flamin mongrel
Tough to find them, especially online. But just a quick sum-up they can sticker any car they think has an "illegal" mod or they "suspect" the car doesn't remain within the vehicle standards rules & regulations.
When you go to the pits, whether its for a new rego or a licky, the inspection will be the same. However, the stickers say what they suspect is illegal & it's what they will look at most. In your case now, because the cops were clueless, they haven't given the pits much detail. When you go there, they will have a look at ur sticker paperwork & think oh goody.
So what I'm thinking at the moment with yours, if it's mechanically good & not too loud (everything plumbed back, no leaks etc), and have a good attitude & explain the story to them you probably won't have a problem. If you think playing ignorant will help you can try it, but remember they will have the rego history etc on the system, so if they go to check on that & see you have have had the car for years, but you told them you only just bought it & they said it was stock, then expect problems.
All I'd advise is make an inspection booking to your nearest centre, do anything you have to with the car & take it there. From what you have said here I can't see you having too much trouble if you are just polite & honest about it all.
got inspected today the guy went over it with a fine tooth comb, picked up an oil leak out of the remote filter, pod filter was a bit loose, steering rack boot was f**ked and the front bar needs repairing and apparently i had no brake lights, gave me 2 weeks will be easy to get off, also mentioned that i get a modification permit for my high mount, pod an bov just to be safe, $14.30 hopefully itl be worth it.
Found the acts, It is part of the ROAD TRAFIC (VEHICLES) BILL 2007, Bellow is clause 73, there are other parts to it...
73. Form and content of defect notices
A defect notice is to --
(a) be in writing in a form approved by the CEO; and
(b) specify the alleged defect ; and
© set out each direction given under section 72(1) and, if
relevant, section 72(2); and
(d) state when the notice comes into force, being either --
(i) when the notice is issued; or
(ii) a later time.
The part that interests me is the "specify the alleged defect" as writing "post manufacture modifications to comply with vehicle standards regulations" is not specidying any alleged defect...
Thoughts?
Here is a link to the bill for those that are interested:
http://www.austlii.edu.au/cgi-bin/sinodisp...ml?query=defect
and here is the link to the Explanatory Memoranda for that bill:
http://www.austlii.edu.au/cgi-bin/sinodisp...ry=defect#disp8
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
