replacing the stock rims with a set of 18x8.5's What's the recommended size of tyre for this size/width of wheels? I'll do the research on the tyre brands myself as there'a a LOT of discussion in that big sticky thread above .. I just need to know the right size. Cheers
Also if someone could just quickly explain the tyre size lingo and what it means that'd be cool ie. 235/40/R17 (or some such)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/
anyone?? looks like I might be getting my new rims today so i'll need to go out and buy some rubber .. I've pretty much decided on Federal SS 595's but I'd like to know what size I'm looking at so as to be able to ring around and find the best price.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835253
Im running Federal SS 595's on my stock rims atm and they are a great tyre for the price.
Im running 235/45/17
Im no expert but here is my basic understanding
235 is the width
45 is the sidewall height in relation to the width
17 is obvisouly the rim size.
I've heard you can go as big as 275's on the back of r34's but you'd probably have to get your guards rolled. Im going 265/30/19's on the front and 235/35/19 on the back with my new mags and i'll be getting mine rolled to be safe.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835284
you mean you're going 235 at the front and 265 at the rear or are you really putting wider tyres at the front? Speaking of which, why is it so common to see people put wider tyres at the back when the rim width is the same ??
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835493
well my new rims are here all ready to go yay! Now I just need to decide on the tyres ... I see a lot of good responses on the Federal 595SS so I might as well go with the flow. Now just to find the right size
The stock rims are only 17x7.5 but the tyres on them are 225/45/17 - thats like 8.85" wide tyre..doesn't that seem a bit wide for a 7.5" rim?
Edited by Delta Force
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835583
what about 235/40/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1cm larger diameter at the FRONTS and 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Edited: fronts were meant to be 235/40 not 45
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836171
what about 235/45/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1.3cm larger diameter at the rears 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Why do you want to put a smaller tyre on the front, do you want it to understeer?
Over 60% of the weight is on the front tyres.
Cheers
Gary
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836190
Cheers
Gary
Sorry I've fixed that typo. it's the fronts that would have a 1cm larger diameter with that sort of setup ... is that any better or still stupid? Should I just go 235/40 front and rear?
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836201
K I've decided to try the Maxxis Z1's due to price being only $179 per corner and me not being able to find ONE negative review for them plus they seem to have won some Wheel's price/performance test.
Now just to get the size right !!
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836342
Yeah my bad, was typing up a quick response while i was 'working' and didn't check it before posting
Bigger tyres on the back is an effort for more traction i'd say, yeah it might/probably will understeer but who really races their skylines on a street setup?...well their daily driven skylines anyway.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836431
I'll speak to the BJ guy tommorow and see what he reckons... I'd "like" 235/40/18 at the front and 255/35/18 ar the rear - but that means the fronts will be 1cm bigger (ie. sidewall 0.5cm higher). I'm not sure if that's a bad thing - I'll see what he reckons and go from there. Thanks all.
Edit: or maybe instead of the above setup, I'll go 245/40/18 all around. That'll give me a higher side wall (better ride comfort??), it's only 1.9cm extra diameter and 3% slower than speedo says (driving 97kmh when it says 100kmh)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836446
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
