replacing the stock rims with a set of 18x8.5's What's the recommended size of tyre for this size/width of wheels? I'll do the research on the tyre brands myself as there'a a LOT of discussion in that big sticky thread above .. I just need to know the right size. Cheers
Also if someone could just quickly explain the tyre size lingo and what it means that'd be cool ie. 235/40/R17 (or some such)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/
anyone?? looks like I might be getting my new rims today so i'll need to go out and buy some rubber .. I've pretty much decided on Federal SS 595's but I'd like to know what size I'm looking at so as to be able to ring around and find the best price.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835253
Im running Federal SS 595's on my stock rims atm and they are a great tyre for the price.
Im running 235/45/17
Im no expert but here is my basic understanding
235 is the width
45 is the sidewall height in relation to the width
17 is obvisouly the rim size.
I've heard you can go as big as 275's on the back of r34's but you'd probably have to get your guards rolled. Im going 265/30/19's on the front and 235/35/19 on the back with my new mags and i'll be getting mine rolled to be safe.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835284
you mean you're going 235 at the front and 265 at the rear or are you really putting wider tyres at the front? Speaking of which, why is it so common to see people put wider tyres at the back when the rim width is the same ??
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835493
well my new rims are here all ready to go yay! Now I just need to decide on the tyres ... I see a lot of good responses on the Federal 595SS so I might as well go with the flow. Now just to find the right size
The stock rims are only 17x7.5 but the tyres on them are 225/45/17 - thats like 8.85" wide tyre..doesn't that seem a bit wide for a 7.5" rim?
Edited by Delta Force
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3835583
what about 235/40/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1cm larger diameter at the FRONTS and 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Edited: fronts were meant to be 235/40 not 45
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836171
what about 235/45/18 on the fronts and 255/35/18 on the rears? Or would that be too weird a setup?
that would give me a 1.3cm larger diameter at the rears 1.5% in speed difference (rears faster) and 0.5cm difference in sidewall height (fronts higher)
Why do you want to put a smaller tyre on the front, do you want it to understeer?
Over 60% of the weight is on the front tyres.
Cheers
Gary
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836190
Cheers
Gary
Sorry I've fixed that typo. it's the fronts that would have a 1cm larger diameter with that sort of setup ... is that any better or still stupid? Should I just go 235/40 front and rear?
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836201
K I've decided to try the Maxxis Z1's due to price being only $179 per corner and me not being able to find ONE negative review for them plus they seem to have won some Wheel's price/performance test.
Now just to get the size right !!
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836342
Yeah my bad, was typing up a quick response while i was 'working' and didn't check it before posting
Bigger tyres on the back is an effort for more traction i'd say, yeah it might/probably will understeer but who really races their skylines on a street setup?...well their daily driven skylines anyway.
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836431
I'll speak to the BJ guy tommorow and see what he reckons... I'd "like" 235/40/18 at the front and 255/35/18 ar the rear - but that means the fronts will be 1cm bigger (ie. sidewall 0.5cm higher). I'm not sure if that's a bad thing - I'll see what he reckons and go from there. Thanks all.
Edit: or maybe instead of the above setup, I'll go 245/40/18 all around. That'll give me a higher side wall (better ride comfort??), it's only 1.9cm extra diameter and 3% slower than speedo says (driving 97kmh when it says 100kmh)
https://www.sau.com.au/forums/topic/217150-what-size-tyres/#findComment-3836446
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
