latly my 32's hicas light has been comen on after a little while of driven.
after driven it around for quite a bit since the light has been coming on i have now narrowrf it down to these factors
if i drive for a long period of time it comes on
if i drive for 5 mins slowly and then i boost the light comes on
the light comes on and does not disapear untilli turn the engine off.
so pretty much i have came to the conclusion that if i boost or do highway driving where the wheels are spinning quite quickly my hicas comes on.
i have taken it to a normal mechanic and they had no idea what a hicas really was so im after specific help
what can i do/check to stop the light comen on
https://www.sau.com.au/forums/topic/217190-32-hicas-lightproblem/
had that problem on my r33 but after trying to find the problem i went under the car two fit the lock bar i found that somthing was eating my sensor wires there were all touching try that if you have dogs or other pets
where is the hicas fluid located? i see the power steering but is there a seperate 1 for the hicas?
Its the same thing really.
Now I gota GTR (Might be the same as GTS-T, Im not sure, just have a look)
- OK so you check the one at the front in the engine bay. Make sure thats topped up.
- NOW open your boot / As you are facing the boot, on the bottom right handside, there is a panel you can unscrew, there will be another tank/resevour, Top that up with powersteering fluid.
The same thing happend to me and what is said above is what I did. End Result = My HICAS Light turned off.
I have posted this before BUT some ppl seem to think the tank/resevour in the boot is for the ATTESA-ETS...
Only other thing I can suggest its to get your mechanicn check the fuese in the fues box, do a wheel alignment and even diagnose the cars ECU to see if it can pick up any faults in the system if the light still does not turn off.
BTW let me know how you go about filling up the rear tank/resevour (thats if you have one, LOL!), if that is topped up and switches off the light then I can say its for the HICAS.
i had the same problem man, fill up your power steering fluid and then fill up the rear hicas aswell, then start the car and drive it for a while for about 5-10mins and then you will know if there is a lak in your hicas system because i had the same problem and my mechanic told me to do that, and also go get a wheel alignment and im pretty sure you would be ok, i was at the stage of removing the hicas but i ended up fixin it, hope that helps mate,
cheers
My HICAS light comes on in my 32 R after several minutes of highway driving also...
All fluids are fine. Anyone know why it does this? Does it do this with all 32 R's or? Maybe I have a HICAS lockbar? Would the light be on always if I had a lockbar or never?
The reservoir in the boot on the right IS for the 4WD system. Still requires power steering fluid, but is not for the HICAS.
Edited by NoFX_Hardcore
Wheel alignment, steering wheel sensor...
Then check the HICAS computer at the back...
Ok just to clear some things up.
Yes the R32 GTR does have a hicas fluid reservoir in the back right of the boot. NOTE any other varient R32 including GTS-t GTS will not have a reservoir there so don't bother looking.
Wheels alignments should only be a last resort IMO. Here's some possiblilites.
1: If you have an aftermarket steering wheel, you SHOULD have a hicas bosskit or your light will stay on continously.
2: Your hicas ECU in the trunk, on the underside of the parcel tray may have a fault.
3: Possible leaks in the steering / low power steering fluid.
4; If your hicas has been deleted you should be able to see a lock bar in there (in this case you don't need to worry about the light)
If all else fails just eliminate hicas altogether. It's cheap and you'll find handling alot more predictive.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
