latly my 32's hicas light has been comen on after a little while of driven.
after driven it around for quite a bit since the light has been coming on i have now narrowrf it down to these factors
if i drive for a long period of time it comes on
if i drive for 5 mins slowly and then i boost the light comes on
the light comes on and does not disapear untilli turn the engine off.
so pretty much i have came to the conclusion that if i boost or do highway driving where the wheels are spinning quite quickly my hicas comes on.
i have taken it to a normal mechanic and they had no idea what a hicas really was so im after specific help
what can i do/check to stop the light comen on
https://www.sau.com.au/forums/topic/217190-32-hicas-lightproblem/
had that problem on my r33 but after trying to find the problem i went under the car two fit the lock bar i found that somthing was eating my sensor wires there were all touching try that if you have dogs or other pets
where is the hicas fluid located? i see the power steering but is there a seperate 1 for the hicas?
Its the same thing really.
Now I gota GTR (Might be the same as GTS-T, Im not sure, just have a look)
- OK so you check the one at the front in the engine bay. Make sure thats topped up.
- NOW open your boot / As you are facing the boot, on the bottom right handside, there is a panel you can unscrew, there will be another tank/resevour, Top that up with powersteering fluid.
The same thing happend to me and what is said above is what I did. End Result = My HICAS Light turned off.
I have posted this before BUT some ppl seem to think the tank/resevour in the boot is for the ATTESA-ETS...
Only other thing I can suggest its to get your mechanicn check the fuese in the fues box, do a wheel alignment and even diagnose the cars ECU to see if it can pick up any faults in the system if the light still does not turn off.
BTW let me know how you go about filling up the rear tank/resevour (thats if you have one, LOL!), if that is topped up and switches off the light then I can say its for the HICAS.
i had the same problem man, fill up your power steering fluid and then fill up the rear hicas aswell, then start the car and drive it for a while for about 5-10mins and then you will know if there is a lak in your hicas system because i had the same problem and my mechanic told me to do that, and also go get a wheel alignment and im pretty sure you would be ok, i was at the stage of removing the hicas but i ended up fixin it, hope that helps mate,
cheers
My HICAS light comes on in my 32 R after several minutes of highway driving also...
All fluids are fine. Anyone know why it does this? Does it do this with all 32 R's or? Maybe I have a HICAS lockbar? Would the light be on always if I had a lockbar or never?
The reservoir in the boot on the right IS for the 4WD system. Still requires power steering fluid, but is not for the HICAS.
Edited by NoFX_Hardcore
Wheel alignment, steering wheel sensor...
Then check the HICAS computer at the back...
Ok just to clear some things up.
Yes the R32 GTR does have a hicas fluid reservoir in the back right of the boot. NOTE any other varient R32 including GTS-t GTS will not have a reservoir there so don't bother looking.
Wheels alignments should only be a last resort IMO. Here's some possiblilites.
1: If you have an aftermarket steering wheel, you SHOULD have a hicas bosskit or your light will stay on continously.
2: Your hicas ECU in the trunk, on the underside of the parcel tray may have a fault.
3: Possible leaks in the steering / low power steering fluid.
4; If your hicas has been deleted you should be able to see a lock bar in there (in this case you don't need to worry about the light)
If all else fails just eliminate hicas altogether. It's cheap and you'll find handling alot more predictive.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
