Item: GTR power upgrade. (Couple parts are specific to 32 & 33 GTR's and can be excluded from sale)
Age: See below, most parts are 4 months / 2000kms
Condition: Excellent
Price: $5300 (have receipts for most items. Buy price was $7974 which is before you add dyno tune and extras thrown in
To Fit: GTR's (piping kit to suit 32 only, ecu to suit 32/33 only)
Contact: PM, email [email protected] or call 0413 250 250 A/H
Comments: I fitted the bulk of this in January 08 and have only done 2000km's since then. As my upgrade came to fruition my financial situation changed and I now have to sell my car. It seems fitting to return my car to standard before selling because it's a better illustration of it's past, and at the same time offer someone with same goals as myself an opportunity to buy the lot in one go and avoid the hastle and waits i went through. This can all be fitted yourself with a shed and normal tools. The only additional expense might be a fine tune on the dyno to add other mods you run, or to get more power out of the tune.
My goals for this upgrade were reliability, response/drivability, economy, to appear stock and to only use parts that were necessary. I experimented with some other expensive boltons only to find they didn't add much value. The AFR's/boost on this tune are very safe and recorded 305rwkw @ 1.15bar (stock internals). I was getting 480kms around town on a full tank and that was using the power regularly.
For the next 2 weeks I will only be interested in queries from people wanting the bulk of the gear. After that I will separate.
Item: HKS GT-SS Turbos
Age: 2000kms / were in storage for about a year
Condition: Near new
Item: HKS S/S front and dump pipes
Age: 2000kms / 4 months
Condition: Near new
Comments: Entire length has been covered in thermowrap
Item: Bosch 044 fuel pump in tank, Nismo 550cc injectors, Nismo Fuel reg, inline Fuel pressure gauge
Condition: Near new except injectors which were bought 2nd hand
Comments: 044 includes Croydon Autosport's GTR speed fitting pack,has been rubber mounted and is silent. If you have an original fuel pump cradle we can swap to save you the trouble. Injectors have been professionally cleaned and flow tested, results were excellent.
Item: Justjap FMIC hardpipe kit - this is only suited to R32 GTR. Deduct $300 to exclude from sale
Condition: Near new
Comments: Piece near radiator feeding TB is covered in thermowrap. Vacuum line installed in piece after turbo for boost controller.
Item: 3" Catco metal cat with 5" body
Condition: Near new
Item: Choice of HKS super sequential or Turbosmart Type 3 Dual port BOV. Deduct $150 to exclude from sale
Age: 2-4 years
Condition: Good working condition. Some scratches on the bodies of both items. I am currently using the Turbosmart item in a fully plumbed back setup for roadworthy purposes.
Item: Blitz I-Color Spec R Boost controller with optional tempurature sensor
Condition: As new, still has the plastic cover on the screen
Comments: This comes mounted in a custom centre console mount that looks great, can be hidden from view and doesn't require cutting into your dash. Temp sensor has never been used and still in packaging.
Item: Power FC with Hand controller to suit R32/33
Condition: As new, comes with custom mounting bracket to bolt ECU straight in
Comments: Tuned by Martin Donnan @ Willall to suit all mods listed here
OPTIONAL because nearly every GTR has these :domokun:
Item: Jasma S/S 3" catback exhaust and K&N Pod filters
Age: Unknown, are the only mods that were on car when i bought it
Condition: good
Price: Add $450
Comments: Exhaust has perfect volume for street. Reasonbly quiet until it comes on boost.
Will aim to get pics up on weekend, earlier if required.
Thanks
Wegs
Edited by wegs
  • 3 weeks later...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
