Car is absolutely immaculate and i'm sure it will not fall short of being impressive.
[sTATE/LOCATION] Melbourne, Victoria
Car 1997 Luxury Spec 200SX
Mileage 159,000KMs but engines done approximately 10 000kms
Extra Comments
Visual Enhancements
Full Genuine Origin Stylish Body Kit
Genuine East Bear carbon fibre bonnet
Full respray in custom Daytona Blue with Silver and Violet
19" Rays Volks GTS rims 9.5" at the front 10.5" Rear
Clear Front and side indicators
Debadged
Super bright white parkers
HID kit
Braking, Driveline, Suspension & Handling:
Nismo Engine Mounts
Balanced factory crankshaft
ARP mainstuds
ACL race bearings
CP Forged Piston
Eagle Rods
Ported Head
Tomei poncams
Tomei metal head gasket
ARP head studs
Greddy plenum
Greddy Sump
Garrett GT3082R turbo
Hypertune Manifold
Sard 850CC injectors
Nismo Gear box mounts
Kazama Adjustable Castor Rods
Lipped rear quarters
Lipped front guards
Rays black nuts
Tein flex height / damper / camber adjustable coilovers
Tein front strut brace
Tein rear strut brace
Whiteline Front Swaybar
Whiteline Rear Swaybar
Brand new (just put in) OS Giken STR Twin plate clutch
4 Pott Brembo Front Brakes
Brembo Rear brakes
Performance:
Apexi Filter
HKS Intercooler
Oil Cooler with Filter Relocator
Koyo Alloy Radiator
Splitfire Coilpacks
Power FC with boost module
Interior:
Apexi Auto Turbo Timer
Bride Brix 2 Driver's seat
Bride Brix 2 Passenger's seat
Bride Retrim for door trims
S15 rear seats
Project MU shifter
Defi Control Unit II
Defi BF Boost Gauge
Defi BF Water Temp Gauge
Defi BF Oil Pressure Gauge
Defi BF Oil Temp Gauge
ICE:
MB Quartz Splits
Rockford Fosgate 4 Channel Amp
Rockford Fosgate Punch 12inch Sub
Price approximately $34,000. As noted earlier it has just had a brand new clutch put in. I have NOT mentioned a lot of the parts which are on the car as the list does not seem to end. Car makes approximate 315RWKW at 1.5 bar.
If your really interested I can work out an inspection.
Call 0421 128 922 for any questions or queries.
Edited by chan
https://www.sau.com.au/forums/topic/217475-1997-luxury-s14a-complete-package/
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
